Whining sound and clunking front end.
Hi guys, 2 problems here.... (1988 944 2.5 Auto)
1) When I start my car there is a terrible whining sound, it goes away as the car warms up. Very loud and annoying.
2) Weird sound coming from front driver wheel. Something seems loose or out of whack. Makes a clunk when going on speedbumps or taking turns.
Thank you for your help.
Old 09-06-2017, 09:08 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello Jackson - have you checked the fan belt for the whining/squeaking sound? Are you able to lift the car and check the suspension? I'm attaching a link to our site's DIY tech articles on the 944 platform if you need any advice on future maintenance or repairs.
Porsche 924/944/968 (1975-1995) Technical Articles - Pelican Parts
Old 09-07-2017, 12:12 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I had the same clunking issue. It turned out to be a frozen shock strut. Push down on the front corners to see if they go down and rebound normally. That's how I found it.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-10-2017, 12:30 PM
1. Your whining sound may be your power steering pump. These sound awful if there is air in the system. Do you have any leaks? How is the fluid level?
2. In regards to the clunking issue. Jack the car up and check the ball joints, tie rod ends, sway bar bushings, and wheel bearings. I had a similar issue, and mine also turned out to be a strut as indicated in the previous post. But it is easy enough to check the other items before you start to pull the struts.
Good Luck. Let us know what you find.
Old 09-11-2017, 06:50 AM
I had the same problem and was a frozen shock strut.
_________________________________________
Towing fairfax
Old 09-11-2017, 06:57 AM
