Hey! Nice Rack! "Celette"
rich's Avatar
Changing from round tooth pulleys to square tooth
Couple of questions:
Can you install the cam pulleys wrong?
The crank pulley has a punch mark on the side. Does it install in tword the engine, or out facing the balancer?
Does it matter?
What about the cam pulleys?
Is there a right and left, or can you swap them side to side?
If there's a difference this may explain my engine issue....
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 12-12-2007, 11:51 AM
Herr-Kuhn's Avatar
The dots always face out...I have seen them put on backwards before and as well have seen a square tooth belt on the HTD pulley.
Kuhn Performance Technologies, LLC
Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane.
Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane.
Old 12-13-2007, 04:28 PM
rich's Avatar
Thanks for the responce, I'm not sure this is the case, I don't have anymore time to look into it now, But If the dot on the crank pulley is facing in twords the block would that change the crank to cam belt timing?
Old 12-13-2007, 04:32 PM
Herr-Kuhn's Avatar
Oops...I told you wrong, they should face back towards the cam housings such that they line up with the pointers which are into the die castings. I was not thinking when I typed the first response. I usually paint the marks on the timing belt pulleys so they are easier to see when you line them up.
It is typical for the right side cam to be slightly off the mark due to the tolerance stack-up of the engine.
Old 12-13-2007, 05:27 PM
rich's Avatar
I know about the cam gears. I thought you were commenting on the crank gear. It also has a dot on side of the gear. That's the one I'm looking to confirm now.
Dot in tword the crank?
Dot out tword the balancer?
Doesn't matter...
Old 12-13-2007, 06:43 PM
Heavy Metal Relocator
rhjames's Avatar
hey Rich,
Porken is the timing gear guru....
send him a PM and he'll answer all things related to timing gears.......
I don't have my FWM's at the moment, or I could let you know for sure.
Ken can tell you right off the top of things-
---Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 12-13-2007, 07:49 PM
toofast928's Avatar
Cam sprockets can be swapped left to right. Ignore the "dots", the Vee notch is what's important. It faces towards the engine to align with the timing pointer.
Make sure all the timing sprockets match the T Belt. All square or all round tooth (HTD).
The cam sprockets are made of soft material and wear in the middle. Use a straight edge and make sure the teeth are not concave. If they are replace the sprocket.
Looking back I always regretted "upgrading" to the HTD T Belt on my 1982. The left cam will always be off 3 degrees. (unless you buy Porkens timing tool).
My advice is to be square.
Tony
Old 12-13-2007, 09:12 PM
Network Native
Danglerb's Avatar
I haven't heard about using a straight edge, just that if the anodizing has worn through in any spot where you can see the aluminum, it should be replaced or "possibly" recoated with something.
Old 12-13-2007, 11:08 PM
toofast928's Avatar
I always installed the crankshaft sprocket dot facing the radiator. Don't think it really matters if the sprocket and T belt are new.
If reusing one or the other and reinstalling oppsite of the orginal rotation, it might afffect the T belt tracking. That is the belt might begin to walk off the sprocket.
Tony
Old 12-14-2007, 04:56 AM
Stan.Shaw's Avatar
Doesn't matter...
Yes, it matters as your timing will be wrong 180' (as I recall) and it won't run. Trying to remember... If you install it backwards don't the timing settings go the wrong way, so advanced shows as retarded, etc. Porken's website has a photo of one a couple of scrolls down at http://www.liftbars.com/docs/32VrManual.pdf
Old 12-14-2007, 04:59 AM
rich's Avatar
I sent porken a pm over on the list but he didn't reply. Maybe he's off the grid for a while or didn't reccognize my sign in or name. Still trying to solve this puzzle.
Old 12-15-2007, 04:33 AM
Stan.Shaw's Avatar
Dumb, I just realized I was thinking dampner and you are talking about the crank pulley. I can't think of any reason why it would matter with the crank pulley. Sorry about that.
Old 12-15-2007, 05:16 AM
