Replacing ignition lock cylinder in '80 928
Hi Everybody.
I am going to attempt to replace my lock and tumbler in my ignition ( where ignition key goes in ) in my 1980 928S Euro. Does anyone have any ideas what is needed to do this? I took my car to a locksmith today and he thought one might have to take part of the dash above the gages out.
Any help is appreciated. Thanks.
john
1980 928S Euro
1983 928S
1988 928 S4
1989 944NA
Old 06-28-2008, 01:41 AM
Network Native
Danglerb's Avatar
Couple tips on nichols site.
http://www.nichols.nu/tip041.htm
http://www.nichols.nu/cat17.htm
pretty sure there is also a nice guide with pictures, but I didn't find it in a quick search.
Old 06-28-2008, 12:04 PM
Thanks Danglerb!
1980 928S Euro
1983 928S
1988 928 S4
1989 944NA
Old 06-28-2008, 12:57 PM
Deadly link worked perfect amazing it's not in the service manual..................
Old 04-01-2010, 09:51 AM
MPDano's Avatar
Remove the Pod and it will all be there in front of you. There are a couple Plates under the Steering wheel that need to be removed (3 or 4 screws), remove the Steering Wheel/Signal Stalk, then 2 (10mm) bolts holding the Pod down. Should be enough slack in the wiring to let the Pod hang.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-01-2010, 10:05 AM
928: Serial Enabler
In this picture I've drilled-out the pin that retains the lock cylinder and am threading the hole to accept a threaded allen screw instead.
Here's the igntion lock and key:
Here's the innards of the lock:
84,85,86 928 cars
Old 04-01-2010, 11:20 AM
SharkHead
JhwShark's Avatar
On my '79 to the left (towards the center of the column) of the lock cylinder on the underside of the aluminum bar is a plug with two wires that plug into a contact. I think I see the wires in this picture.
What is this contact for?
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 04-01-2010, 11:37 AM
MPDano's Avatar
I did exactly what Lanseer is doing. I threaded it and put a small allen screw in mine.
Old 04-01-2010, 12:41 PM
Kool
AirtekHVAC's Avatar
Resurrection Thursday......I have to remove this to repair/replace the rod and pieces that the key turns, to turn the electric switch....anyone else had to change the rod and associated parts? 928I has the kit.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 11-13-2014, 08:25 AM
stepson's Avatar
IIRC, that is the sensor that detect a key in the ignition. On the Stepson, I have the wires from the factory, but no sensor. I thought that was strange.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-13-2014, 10:34 AM
