Need to replace driver's door lock on my '79.
Hello, 928 is in the shop with door apart, and mechanic said the door lock cylinder input arm is broken. I guess I need the driver's door lock cylinder assembly? I had put the key in a while ago, turned it (there was resistance) and "pop". A used one would be fine, just hoping to find one ASAP for the Seattle area? Thank you!
Old 06-30-2008, 02:33 PM
Heavy Metal Relocator
rhjames's Avatar
any of the major 928 parts suppliers should be able to help with this-----
928 Int'l
928 Specialists
928sRus
to name a few......
not sure if Pelican Parts has this as I did not see one listed.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 06-30-2008, 05:26 PM
Old 928 Guy
surfdog4's Avatar
there is a good chance that 928 International will have used ones...
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 07-01-2008, 11:57 AM
