I have an 84 Euro 928s with 4.7 LH-Jetronic system.
I need an instrument Cluster, and since there seems to be a lack of: 928.641.114.34 or 928.641.103.34 out there can I use one from a different year, does Auto/manual matter, euro vs. US connections issues? Any insight would be of great help. Thanks ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1984 Euro 928S 310HP Stock ![]() |
Do you need the whole cluster or is there something about yours that isn't working? The foil circuit boards for the 84 are NLA as far as I know.
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
There is not a cluster in it at all.
928 inter has a new 85/86 euro cluster. Not sure if it will fit.
Glenn
87 928 - AT, Strosek Ultra Wide Body Kit Black/Burgundy :jumper: 88 928 - AT, RMB, AutoThority Chips, GTS C1 Rims Metallic Silver/Black |
Thats the problem, no one knows if it will work or not. Can I wire in something else, or rewire what I have to accommodate whatever.
Network Native
The tach needs to be from a two distributor car, US or Euro, but I am not 100% sure of anything else.
The cluster out of my 84 Euro is in a "bit" of limbo status, sending you PM to discuss it. |
The best fit would probably be a cluster from a late 84 to 86 twin dizzy 16v Euro.
Most clusters are specific to the year and also to US & ROW. 84 to 86 Euro's are rare over here but not in Europe and I am keeping an eye out for one for you. I have a lead on a US cluster and it may be worth a try to see what works and what does not. Once it arrives I will lend it to you so we can test some theory and narrow the choice somewhat. You will need some patience me thinks 8>)
www.************ |
Thanks ROG100, I responded to your PM Danglerb, and thanks so far. Not much left to do in getting this ol' Shark back in the water.
mrtiffen,
There is a 928 GTG in Austin this Saturday - are you going? I may be able to bring the cluster with me. You do not have to come in a 928. Roger
www.************ |
Heavy Metal Relocator
Adam--this would be a deal for you to consider, if your budget allows. I would go but I'm busy trying to put together a truck deal. if I get it completed, we might truck -pool over there for the day......(?) I could at least get Roger to bring some rod nuts and an oil pan gasket to put the 4.5L short block together. --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Network Native
I noticed this ad has a cluster in tx craigslist.
http://dallas.craigslist.org/dal/pts/987931156.html |
i'm going thru same challenge, and found wiring and clusters are year specific. 1982 thru '84 were the same, and '85s were different. look on ebay in Germany there are a couple of clusters right now. Of course the almight American dollar isn't worth as much as the Euro.
This is always a problem. I wonder how hard it would be to manuf. the foil?
Recovering dismantler
Or make up a circuit board/ harness to accept the 84 - 86 wiring harness and convert to a more common, available 82 - 83 cluster. Fab'ing up a pcb is fairly easy and cheap, assuming you can get the plugs to go on the cable to the 'new' cluster. You may loose a couple of functions, but at least you would have a working cluster.
I'm not offering - but could be done...
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Given enough time and money I suppose It would be possible; after all Porsche did it. I found another mounting plate with the foil, paid $25 more than what I sold an '87 cluster, just so I wouldn't have to do something like that. I found the tabs were the foil folds around are very brittle. I just wanted to replace my cracked pod and broke the tab on mounting plate. Now I'm VERY CAREFUL unplugging cluster.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Dean Bolejack
Instrument Cluster
If you have not found an instrument cluster, I have one from a 1982 Porsche European 928.
Dean |
Thread Tools | |
Rate This Thread | |
