Icedt
Well...............
I did the water thing. Sucked about .8 liters into it. It burns water well, not a speck of white smoke. ????? Didn't seem to care that it was on an IV.
After I was done, I hooked everything back together, let it come down to idle speed and it ran for about 45 seconds and then died. Just like before. Tried also to run some Carb cleaner after that and same results.
I put insurance on it for tomorrow and Saturday just in case so I am going to do the "italian tune up" anyways, since it will always restart when it dies. I will just get out on the highway where I don't have to stop for a light.
Old 06-11-2009, 07:18 PM
OB-Wan
SharkSkin's Avatar
Some people have had success freeing up a sticky ISV with WD-40. In this case you are using the WD as a solvent rather than a lube, so be liberal with it. Won't make any difference if the problem is elsewhere though.
Another thing you could try is re-seating the chips and connectors in the LH/EZK boxes(also see if they are 3rd party chips). If that fails maybe send them to one of the rebuilders like John or Rich and have them check them out.
Dave A.
1978 928 5spd
My 928 Site
Old 06-11-2009, 10:33 PM
lizard928s's Avatar
Try the italian tune up first.
BTW, I have sent you the invite to the list. And I will get the other fellow to contact you.
Old 06-12-2009, 02:20 PM
MPDano's Avatar
I heard of that, but what exactly is an Italian Tune Up?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-12-2009, 02:39 PM
Network Native
Danglerb's Avatar
Zoom Zoom. Wide open throttle runs.
Old 06-12-2009, 04:37 PM
Icedt
solved!
As Anakin Skywalker said when his pod racer started up "It's working, It's working!"
Well I did as Mike suspected and Lizard said to. I drown the ISV first with water (no smoke, imagine that) and then with carb cleaner and then some WD-40. Then did the Italian tune up part. It has pretty much fixed it 95%. Obviously I will need to assault the ISV later (TB and WP first) but it runs like it did before. Stalled once on me at a light with the A/C running but it always starts right up and then it gives you another reason to punch it off the light.
Thanks to all who suggested stuff for this.
In the end it may have been the ISV clogging up from me doing what I thought was good thing and that was to start it a couple times in the winter. This car probably doesn't like that. If your are going to start me, DRIVE me!
Needing an MAF and an O2 sensor at the same time didn't help the diagnosis any and this does not show up on a Bosch Hammer, just in case you ever have the same issue.
Now for the TB.....
Old 06-15-2009, 07:05 PM
lizard928s's Avatar
As I said Travis. If you want to come down this way we can go over the tb/wp with you.
But glad you have it almost there.
Old 06-16-2009, 02:06 PM
Icedt
thanks for the offer, but I could never get away to drive there during the summer, I'm in new home construction and it's rocking again.
There is an excellent write up by Pirtle? and I am comfortable doing that. Fixing things is not the problem, it was figuring out what to fix!
Old 06-16-2009, 07:54 PM
Network Native
Danglerb's Avatar
This guide by Jack Kelly is HIGHLY recommended, details on bolt torques, pictures of each step.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190309265131
Old 06-16-2009, 10:01 PM
