81-2 competition pkg?
How do you tell if a 81 or 82 car is a competition group/pkg car? I have looked through the option codes and dont see an option code for it like some other special models. Do you look for a bunch of seperate option codes? Is there any difference between an 81 & an 82?
Thanks for any help and direction, Dave
Dave 82 928 Weissach #14 |
I can't remember the option number but the main visuals are: Front & rear spiolers, gold colored anodized wheels, and larger front brakes.
99 Boxster 5-speed 12 Acura TSX 6-speed |
Network Native
I think it was 82 only and just the brakes and cosmetics of the 83 S model, but still with the 4.5L older motor.
my 81 has a front and rear spoiler , lsd, and it says 928s on the rear bumper
Network Native
In 1981 the package included sport seats , wheels (16" Flat Dish), shocks and front and rear spoilers, possibly LSD as well. In 82 the Sport Seats were an option to the comp package.
I THINK the code was 471...sport group 1 AFAIK. |
It was sport seat (none power) and LSD,
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos) |
I had an 82 model and my codes were 471 ( sport group 1 ) and 409 ( sport seats ). My car did have the competition package. I have heard from others that the sport seat option was changed from 81 to 82....non powered as you said....which I really liked.
My 1984 928s has the comp package as well
Thanks guys, so 471 is what I need to look for. Should it still have 220 for lsd or is that covered in code 471?
Network Native
Best to verify you actually have the LSD rather than the code, check the trans ID, or with the car in the air turn one wheel and see if the other turns the same way or not.
Good point.
So a G28/05 is regular 5sp for 81 but what would lsd be?
due to the sychro problem on early trans I think it is safe to say you have to verify limited slip through inspection... many have swapped trannies instead of rebuilding. I found out after I sold my early 928 that it didn't have the correct year tranny in it.
Network Native
G28/05 shows the model year or trans version something like that, it should also have a few more digits like G28/05 xx yy ssss, where xx is blank or a differential code (12 AFAIK is LSD), yy has something to do with gear ratio options, and ssss is the serial number.
http://www.928registry.org/928-Option-codes.htm Interesting that code 471 on the registry is rear spoiler 87 to 89...so this code was "reused. Also I noticed sport seats code 409 is 83 to 85...but I KNOW this was the code in 82 as well so there are some inaccuracies it appears in the different list of codes. Last edited by Dean_Fuller; 03-10-2009 at 02:46 PM.. |
