Need help identifying hoses!!!!!
i have quite a few hoses that lead to nowhere
![]() . some of them have unique bends in them so that might help out with this process. if any of you know where or what these hoses go to, that would be awesome. here are the pics:the one that goes down the intake runner and turns a hard left ![]() the hose goes down to the other side of the block. my best guess is a coolant hose but i really have no clue ![]() close up ![]() and then there is this thing.... it comes off of a plastic tee on the bottom left of the picture. i dont know whats supposed to connect to the tee or where this hook shaped hose is supposed to go either. ![]() ![]() i just know it comes down and around to the back of this thing which is to the right of the bell housing ![]()
1982 928S euro M28/11 That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..." dammit! I'm such a slut~ N! -Normy |
and also... what is this thing and where the hell is the hose??
Looks like your missing your Diverter Valve. This valve runs air to your airbox or exhaust. The vacuum line is what controls the valve.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
you mean i am missing the actual diverter valve, or its not connected to anything...
Clutch slave cyl. No hose, bleeder screw. A good thing-- one less hose to worry about!
"Por ' sche" is a two syllable word. "79" US |
YEAH!! i love good news
anybody have any idea what that thicker hose it??
Looks like Air injection and Tank ventilation circuits. MPDano is right--something is missing! Maybe this will help? Happy hunting!
John ![]()
Network Native
Most of those bigger hoses will have a Porsche part number, makes for easy ID.
Hose in question looks to be #24 in the upper diagram, and all that stuff below it appears to be missing and needs replacing or figuring out how to do without. |
That bad boy is gone, missing, nada, kaput. I will take a pic of mine and show you what it should look like.
Here you go. It always helps me better to see actual pics rather than diagrams. Puts into better perspective. You should also have a long tube going across the passenger cam cover to a host that goes to the Smog Pump.
MPDano-That engine looks great! Where did you get the blue Plenum intake couplers? All I have seen is red.
Any problems running with the exposed TB? Looks nice! John And the blue air intake couplers?
Exposed TB is fine so far. I only got about 400 miles on her since I got it running. The Blue Silicone Couplers were one single hose and I cut them down to size very carefully with an exacto knife. They work great. Lot's of choices in colors too.
If you don't need smog in your state, just block the hose and vacuum line.
ok?... its that simple? no removal of lines or parts?
Before you fix the missing smog hose parts etc....take a look those 2 fuel lines!!!!!....in pictures 1/2/4
my oh my, there'a a fire waiting to happen!...i had to do mine too :-) I started my car up the other day....a buddy of mine says...."whats all that fluid leaking under your engine?!!"....holy cr@p!!...a gas leak...and a bad one too!
John ......... 1978 Porsche 928 5sp LSD 1982 porsche 928 5sp LSD |
