MPDano's Avatar
Need Help on CIS A/F & Idle adjust
Ok, did a little cleaning on my Fuel Distributor (maybe I shouldn't have). Here is exactly what I did:
1: Removed all fuel lines from it.
2: remove distributor
3: turn over and bend tab holding plunger in place
4: remove plunger and clean carefully with carb cleaner
5: took piece of tubing and wrapped with clean cloth and sprayed carb cleaner on it and used this to clean inside plunger area.
6: put plunger back in and bent tab back.
7: removed fuel inlet fitting to expose fuel screen inside (cleaned with carb cleaner), it was a little dirty.
8: put all back together and put distributor back on and connected all fittings.
9: started up with a few cranks and let it warm up
10: took it out for a spin. Seemed like more power and more responsive.
11: seemed to be running lean now, low idle and in gear it will die (automatic) after fully warmed up
11: 1/2 turn counter on idle, which brought the idle up to 900, 1/4 turn richen and it seemed to idle smoother
12: test drive and it is still responsive but very lopey while in gear idling.
This is where I stopped. Did I miss something? Any suggestions?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-14-2009, 05:40 PM
Network Native
Danglerb's Avatar
Dancing with the Devil Leo ...
Old 06-14-2009, 06:05 PM
MPDano's Avatar
Dang, not even a useful *peep*
Old 06-14-2009, 09:35 PM
BB500's Avatar
Well, I'm the last person to ask...........lol.
Old 06-15-2009, 10:37 AM
american-kiwi's Avatar
i gave advice in the past , but no-one listens
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 06-15-2009, 11:29 AM
MPDano's Avatar
I'm listening
Old 06-15-2009, 11:46 AM
Network Native
Danglerb's Avatar
"BB500...have you adjusted the mixture yet?..the 3mm allan in front of the fuel dist'..its a little spring thingy...you might need to turn it up a little...take the air cleaner off...easier to do that way...clockwise rich...counterclock lean...it will fire with the startup cold valve (shot of fuel)...but be too lean to keep running...you'll need a long 3mm allan to do this...as you have to push the allan down to contact the adjuster...but dont push too hard, just hard enough to feel it grab the secondry adjuster inside ...get someone to help you...get them to startup the engine(keep starting)...till it will run with the adjustments...hope this helps you
John"
MPDano's Avatar
John"
If this was it then I am already past this point.
I did notice when I set the distributor back on, it kinda teetered, but I suspect this was the plunger sitting on the plate teeter.
Idles at 900, but as soon as you put in gear, the idle is around 200 or so. Does this sound like vacuum leak somewhere? Idle adjust not right? I seem to notice more air noise from the plate area.
Old 06-15-2009, 11:52 AM
MPDano's Avatar
Wow, are Raymond and I the only ones with CIS Injection on this Forum?
Old 06-16-2009, 07:37 AM
rjm65's Avatar
If it was teetering, then the dist might not have been fully seated. You might've had it just up to the point where the o-ring at the base was making contact. When you started to torque things down with the 3 screws, if you didn't tighten them evenly, the fuel dist could've gone down at a slight angle and could've pinched the base o-ring, which would give you a vacuum leak and resulting lopey idle.
Old 06-16-2009, 09:02 AM
devilinblack's Avatar
No, I have it but mine works and there's no way I'd mess with the fuel distributor at this point unless the car quit running. Oh yeah, I also have the proper test gauge and the WSM with the testing procedures.
Stephen Powers
1978 US 5-Speed
New SoCal928.com Community Site
Old 06-16-2009, 09:15 AM
MPDano's Avatar
Ok, this is what I was thinking too. I don't remember there being an O-Ring there. I will try and remove it this week sometime and verify.
Can you show me in a diagram somewhere that there was an O-Ring between the Distributor and Base?
Old 06-16-2009, 10:00 AM
EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
why is it such a scary thing to clean the fuel distributor? am i missing out in another PITA operation on these 928's?
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 06-16-2009, 11:57 AM
MPDano's Avatar
Yup, it's a scary thing. The thing is, I didn't open the distributor, just the plunger and cylinder. This is why I am siding with rjm65 on this, it has to do with the mounting surfaces.
Old 06-16-2009, 12:21 PM
BB500's Avatar
Leo, guess what??? When I removed the center console, behind it was this block of vacuum lines. Looked like 10 green hoses and few other colors all together in a brick like thing.
Well, it wasn't even plugged in!
You think this might have been what was causing my car not to run? Or is this just for the heating/cooling system? I don't know how this thing must have come undone, unless the person that butchered the stereo had his hands on this as well.
Old 06-16-2009, 02:53 PM
BB500's Avatar
Leo, if your f.d. is still off, you should throw mine on there to see if your car runs. I think the guys at autostebalhaus or whatever didn't even touch the car. Dude, you should stop by the new place so you can see my progress on the teardown.
Old 06-16-2009, 02:56 PM
MPDano's Avatar
I would say that would be a nice source of a vacuum leak.
Old 06-16-2009, 02:58 PM
rjm65's Avatar
You can see the o-ring in this pic Leo, #2.
Old 06-16-2009, 04:34 PM
MPDano's Avatar
Oh damn, that wasn't there when I pulled it off and put it on. Is this part of your O-Ring set? This is my vac leak for sure.
Old 06-16-2009, 08:30 PM
s928s's Avatar
MPDano..I have a bunch of those "o" rings if you need one. I believe it is 33mm ID x 2mm. I just rebuilt my fuel distributor because I had no output at cylinder #6. Runs better now without the miss but I still have some fine tuning to do. Just send me a PM
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 06-17-2009, 04:50 AM
