Architecture & Porsche's
My 928 race car build progress photo thread
Hi guys,
Been building my racecar with my buddy over the last couple of years but getting close now.
Car is an '82 no-sunroof coupe, stripped of in-car undercoating.
'86.5 running gear: brakes, suspension, engine, ecu(s), harness, cooling.
928Turbosports/Porschesolutions turbo kit (stage 4)
Porschesolutions racing sway bar kit
Porschesolutions anti-bump-steer tie rods
Porschesolutions racing oil cooler (modified) kit
Porschesolutions 14" racing brake kit (not installed yet)
S4 LSD rebuilt by 928INTL transaxle, rebuilt 86.5 1/2 shafts.
13x10x1.5 Setrab NASCAR oil cooler, 23' of -10AN hose locates the cooler where the battery box was, pair of 3" NACA's force-feed the cooler via the rear 1/4 window.
Gauges are custom Speedhut gauges modeled after the Ferrari F430, & all have adjustable warning modes for high/low ranges, linked into a large warning light.
Face was laser-cut out of aluminum & covered in suede. Shade cover is suede covered Lexan.
Two Halon bottles: one hand-held, one cable-actuated.
Been wet-sanding all week: get's buffed on Sunday
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-29-2010, 02:22 PM
Right side with anti-bump-steer kit
Left side without ABS kit; notice tie rod angle for a 1.5" lowered car: dramatic.
Note oil cooler in rear:
Engine from below:
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-29-2010, 02:28 PM
928s's Avatar
That looks like a hell of a lot of work! Well done and great pics too.
Old 04-29-2010, 02:46 PM
get this: I found the car (for free) in a garage/barn outside of town, during a trip to buy 928 parts for a 928 track car 3 years ago: car was on blocks: stripped chassis. Took 16 people to pick it up off the blocks & place it on a trailer, then back on blocks in the garage to start getting it to where it could roll for paint & such: quite a task!
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-29-2010, 02:48 PM
MPDano's Avatar
I see it's an OB with S4 Front Calipers. Did you do that or does your year come with those? If not, did you do S4 Front Suspension Parts or the Caliper Adaptors?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-29-2010, 03:42 PM
Fabio421's Avatar
I love the rear quarter windows. What are those NACA ducts feeding, the oil cooler? Is that an engine or diff oil cooler? I'm assuming diff. Post more interior pics please. Especially of the cage.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 04-29-2010, 05:00 PM
Petie3rd
Mrmerlin's Avatar
Mark that looks great, I hope that you car runs well.
I would suggest that you make an S out of the front brake lines try turning the fitting on the caliper upwards if that wont work then consider rerouting the body line so it faces upwards , the way you have it now the lines may tangle with the suspension, also consider wrapping the coiled plastic that comes with the rubber lines over the steel lines so they wont abrade any other metal parts.
Add a flex duct to the alternator so it wont suck up stones
Old 04-29-2010, 05:10 PM
MPDano: '82 car with 86.5 suspension & brakes: bolts right up.
Fabio421: Left side NACA feeds the oil cooler, right side NACA feeds the tire well, which was converted to an air plenum for the turbo's air filter (See picture).
Mrmerlin: The brake lines are not tight yet: I'm preparing to install 14" rotors.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-30-2010, 06:26 AM
Whoops, I had that backwards: left NACA feeds the air filter, right NACA feeds through the tire well into the carbon fiber oil cooler shroud.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-30-2010, 06:34 AM
Fabio421's Avatar
Oh, I didn't realize that this car was turbo charged as well. What class do you plan on running? The turbo will bump you up in class but the cage doesn't look like it has the required side protection. DE only?
Old 04-30-2010, 07:09 AM
GT1R/S because of the boost & size of the engine. For DE it's fine: I'll take a year for my buddy to get acclimated enough via DE's to be able to be certified for PCA racing. At that point we'll go back to finish the cage. Great cage work, but the guy had family issues & couldn't finish it during our required time frame, so it needs to go back.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-30-2010, 07:12 AM
s928s's Avatar
looks great mark..alot of hard work..when it the track debeaut...?
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 04-30-2010, 07:16 AM
harborman's Avatar
Not only a lot of work but many $$$$$. Hope it all works out. Impressive!!
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-30-2010, 09:45 AM
You've made a lot of progress since the last time I saw it. And here I am still F******* with the my WUR!
1982 928 S Euro 5 speed
Old 05-01-2010, 03:27 PM
lizard928s's Avatar
Where did you get the bumpsteer kit? or did you make it yourself (what I am planning).
Also what is the ride height you are running with?
Old 05-01-2010, 09:07 PM
I had them made: hardened steel. I have an extra set, & plan to sell them too. Should work out great. swaybar is badass: I have a few of those left too: had to make a few sets to make it worth my while.
Mark
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 05-05-2010, 07:09 AM
Picture doesn't do it justice: 25 hours of wet-sanding, 5 hours of cutting, polishing, buffing, & 8 hours of final (around the hard-part) polishing. Almost time to wax.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 05-05-2010, 07:10 AM
