Speedometer problem
I have rebuilt 1979 motor , Now the engine start and revs high at 3000 RMP, How can i slow the engine down please? If i turn the Distributor it slows but also the timing go out, The Speedometer indicates 100 miles /hour while standing still,Anyone knows cure for this please?
Network Native
High idle usually means the idle screw on the front of the throttle is improperly adjusted and/or vacuum leaks in the intake. Leave the distributor for setting the timing.
Clean the grounds, check the wiring. |
Petie3rd
remove the throttle cable from the intake connection and see if this still happens if so then you have a throttle body problem if it goes away then have a misrouted throttle cable
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I know having a hugemongous vacuum leak will cause this. Specifically the Decel Valve hoses. I accidentaly pulled the Decel Valve while the engine was running and I thought the engine was going to blow up. It will be on the opposite side of the Throttle Lever on Throtle Body.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
