GTS engine and gearbox spotting?
Couple of questions please:
(1) Is the GTS engine code located at the same place as all other 928's, ie. here? http://porsche928forums.com/download/file.php?id=1278 (2) Any way to tell a GTS manual-gearbox from an S4 gearbox? - that is, when buying the car. Gearbox in car. Cheers... going to view one candidate with a mate, hints welcome.. ![]()
'76 930 |
Petie3rd
1 Engine codes are all in the same place it will tell you what block you have-
GTS trans 1992 to 1995 should be G28.57, it should also have an oil cooler and a PSD fitted quite a bit different looking from an S4 unit G28.13 1987 to 1988 5 sp G28.55 1988 1989 CS and adopted to the 928GT 1989 to 1991 should have PSD
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Thanks Mrmerlin, very good info. Engine block identification should be easy now.
![]() - transmission pictures seems few, tried google, but will need to search a bit more still.
'76 930 |
