GTS engine and gearbox spotting?
Couple of questions please:
(1) Is the GTS engine code located at the same place as all other 928's, ie. here?
http://porsche928forums.com/download/file.php?id=1278
(2) Any way to tell a GTS manual-gearbox from an S4 gearbox?
- that is, when buying the car. Gearbox in car.
Cheers... going to view one candidate with a mate, hints welcome..
'76 930
Old 11-24-2010, 09:35 AM
Petie3rd
Mrmerlin's Avatar
1 Engine codes are all in the same place it will tell you what block you have-
GTS trans 1992 to 1995 should be G28.57,
it should also have an oil cooler and a PSD fitted quite a bit different looking from an S4 unit
G28.13 1987 to 1988 5 sp
G28.55 1988 1989 CS and adopted to the 928GT 1989 to 1991 should have PSD
Old 11-24-2010, 09:56 AM
Thanks Mrmerlin, very good info. Engine block identification should be easy now.
- transmission pictures seems few, tried google, but will need to search a bit more still.
'76 930
Old 11-24-2010, 10:25 AM
