Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Hot air coming from under steering wheel?
So i took a nice cruis this evening. No A/C so had the windows down.
I noticed a lot of heat coming from under the steering wheel. Normal?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 07-31-2010, 06:58 PM
Yes, mine gives off heat everywhere.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster.
Old 07-31-2010, 07:31 PM
Don Mega
My car also gives off lots of heat from the center console and the gear shifter on my automatic. I plan to fix my A/C soon. Will the car still give off too much heat?? Or will the a/c make it bearable?
Old 08-01-2010, 02:53 AM
Kyle C
Could you have a faulty HVAC control unit that is not closing the heater valve?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-01-2010, 06:56 AM
Petie3rd
Mrmerlin's Avatar
go to 928 SPECIALISTS ONLINE STORE - 30,000+ 928 Parts - 928 SUPERCHARGER KITS! and on page 2 under tips and links find Wallys guide to checking the HVAC system this will guide you to how to inspect and repair the leaking pods.
Once the vacuum leaks are fixed the hot air should stop unless you have selected it on
Old 08-01-2010, 08:30 AM
MPDano's Avatar
Our cars are plagued with vacuum issues. Seems as though everthing back in the day was deisigned to be controlled by it. Just one of the many gremlins you'll be chasing. Lot's of old vac lines and tore diaphrams. Although most everyone has these issues so shouldn't be too hard to locate your specific issue.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-01-2010, 09:38 AM
Don Mega
Another question related to the HVAC system...on a fully functional heating/cooling system of the 928, is the owner able to open and/or close the air vent with moving a switch or press of a button like current cars? Because I'm forced to smell the outside atmosphere of wherever I'm driving. Which button is vent closed? Vent open?
Old 08-01-2010, 09:46 AM
Rockin' NW Arkansas
when i turn my control on (heat or a/c), i get a plume of white smoke from under the glove box and that sweet aroma of burning wire. i had to pull the fuse. a project for a later date. anyone got an idea what would cause this? from what i can see, wires look fine.
Matt
Old 08-01-2010, 10:36 AM
Maleficio's Avatar
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 08-01-2010, 10:40 AM
928 Newbie
dcrasta's Avatar
There is a seal on the transmission hump, when your motor mounts collapse (as they all do) the seal is not held tight and this allows hot air from the engine/exhaust to flow up into the car. Its worse if you open the sunroof because of the draft it creates. One solution is replacing the mounts, or using a JagerMount setup (thick slab of rubber between the engine oil pan and the crossmember.
Old 08-02-2010, 09:48 AM
