Kyle C
Source of engine rattling identified
Ever since I replaced the timing belt, water pump and all idler/tensioner pulleys, my engine has been making an odd rattling sound as if the bearings in a pulley were bad, but the sound wasn't quite consistent enough. After taking all the covers back off and running the engine with just the timing belt installed (no fan or acc. belts) I discovered that the timing belt is bouncing up and down between the passenger side cam and water pump pulley, and hitting the small idler which lies on the tensioner pivot bolt, thus making the rattling noise. Has anyone had a similar problem? It is much more noticable around 1500 rpm. As far as I can tell the timing belt is tensioned properly (I have the aftermarket tool).
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 10-13-2010, 07:26 AM
sounds like worn teeth on cam pulley / main pulley. I would check all the teeth on both cams, on the crank, and the one on the oil pump.....but I really do think you have worn teeth on at least one and more likely on more than one....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 10-13-2010, 09:59 AM
Kyle C
IIRC one or both cam gears had some minor wear where the finish had worn off several teeth. Is that enough to cause this? Pretty sure the crank and oil pump were fine.
BTW is the timing belt ever supposed to contact that particular idler, ex. when it is cold or when up to temp?
Old 10-13-2010, 10:11 AM
That is exactly what that idler is for, to keep the belt from bouncing too much. I think you need to check belt tension again. (when cold of course)
Old 10-13-2010, 03:39 PM
Kyle C
Alright, I know I checked the belt tension about 1K miles after the service and it was loose so I snugged it up (using tension tool of course). But since then I have gone another 2k miles, so I will check it in the morning.
BTW does the oil-filled timing belt tensioner slacken or tighten the belt as the engine heats up?
Old 10-13-2010, 06:55 PM
Petie3rd
Mrmerlin's Avatar
the tensioner releases tension as it gets hotter.
What kind of oil is in the tensioner,
what kind of pump did you install ,
what kind of belt did you use.
What was the condition of the idler rollers??
Do you see any marks on the belt ,
has the belt gotten oil or coolant spilled on it??
Old 10-13-2010, 07:25 PM
Xlot's Avatar
Did you install new plastic bushings in the idler arm during your timing belt job?
Various manual S4's
Old 10-14-2010, 03:25 AM
Kyle C
Yes, everything that should be replaced during TB service was replaced
80-W90 gear oil in tensioner
all new idler rollers
new Laso water pump
new belt (of course), Contitech I believe
No fluid has contaminated belt, I replaced all cam seals and cam housing gaskets as well + t-stat and water bridge gaskets
what sort of marks am I looking for on the belt? Perhaps I will just take a picture of it
Old 10-14-2010, 05:30 AM
