MPDano's Avatar
Alternate Kick Down Relay?
Is there an Alternate Solution or do we have to use the exact one? Just wondering as the Relay is $60
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-09-2011, 07:35 AM
vdubr928's Avatar
For auto trans?
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 04-10-2011, 06:25 AM
MPDano's Avatar
Yup, Automatic Tranny
Old 04-10-2011, 06:38 AM
vdubr928's Avatar
Used one ok? I let the fuse panel from my auto go to a local guy with. 5 speed. Bet you two could work it out. If you're interested in a working used one let me know and ill have him chime in.
Old 04-10-2011, 06:58 AM
MPDano's Avatar
For sure. He can post or PM me. I'm kinda here a lot
Old 04-10-2011, 07:01 AM
MPDano's Avatar
Didn't hear anything from vdubr's buddy so ordered me the Kick Down Relay and a couple ones that use the same as the Horn Relay.
Hopefully this $60 Relay fixes my Kick Down In-Op. My Euro doesn't have a Kick Down Relay but must be hard wired.
I had a few bad relays in my "S" CE panel so I bet this will work. Will keep you all posted.
Old 04-18-2011, 01:03 PM
MPDano's Avatar
Yikes! Just notified by Pelican that the Kick Down Relay # 92861810900 is NLA. Still looking for one then
Old 04-19-2011, 01:58 PM
MPDano's Avatar
I was wondering if the Switch under the Accelerator Pedal is a grounding switch. I'm not very good at reading schematics, so does anyone know the answer to this question?
The reason I ask is once I get my Kick Down working, I want to install a KD Bypass switch that is lighted. They are 3 prong so I assume I need one of the prongs to be ground.
Old 04-20-2011, 10:42 AM
Recovering dismantler
neil30076's Avatar
Leo, the kick down switch provides 12v from the '15' rail to the relay pin 30, so it is not a grounding switch.
Wire your light between K1 and ground, and it will be on when KD switch is active.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 04-20-2011, 11:42 AM
MPDano's Avatar
Thanks Neil! Exactly what I needed. Looks like a non-lighted rocker switch is what I need.
Old 04-20-2011, 11:46 AM
harborman's Avatar
If it's relay XV at least on my 86, it appears to be a solid state relay. A see one terminal goes to ground, so possibly the switch is putting voltage on it. Be careful what you hook up to it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-20-2011, 11:56 AM
MPDano's Avatar
Yup, theres a little circuit board in there. I opened it up to see if there was any obvious signs of it being bad. Nothing noticeable. I already bought a good used one from the 9 source about an hour ago. He said it's tested so if this doesn't solve it, then it's gonna be the part on the tranny.
Old 04-20-2011, 11:59 AM
neil30076's Avatar
You can do either, if you want the switch lite all the time, connect to the light + to the circuit 15 side, if you want it to light only when kd bypass switch is hit, connect the light + side to K1.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-20-2011, 12:31 PM
MPDano's Avatar
Interesting. Will give that a go, which I can do on my Euro now since the KD works. Except I can't test it legally since I need to Smog it (reg fees already paid).
Does the k1 wire have a different color that you can tell?
Old 04-20-2011, 12:40 PM
neil30076's Avatar
Looks like the K1 wire is gr/br - the other wire on the kd switch under the gas pedal is black, which is the '15' wire, should should be easy to find!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-20-2011, 01:58 PM
harborman's Avatar
There is usually no way of telling if a solid state devise is bad without testing it, other than you know it's malfunctioning. Sometimes even testing it without a high empedence meter can actually damage the device. Normally, they short out, but other components associated with it's operation can cause the failure. Solid state devices are prone to destruction by voltage spikes. Anyway, my point is if you put a cheap meter on it, it may cause a failure of the device. Note the schematic diagram of the relay, it has a symbol of a transistor in it, so you will know it's not a mechanical relay.
1986 928S
32 valve engine
Old 04-20-2011, 04:57 PM
MPDano's Avatar
I was able to fix an old CRT Monitor and an old HD 30 Flat Panel TV a few years back by looking at an obvious burned Cap/Transistor or a broken circuit, then by using a diagram (schematic?), figure out the proper Cap, Resistor that belonged there. Using my handy dandy soldering iron, flux, paste and a magnifying glass, I was in business. It's been a few years but I think it had to do with the bands and colors. Anyways, that's what i was looking for. If I had to resort to any testing, it made it's way to the dumpster.
Old 04-20-2011, 07:48 PM
harborman's Avatar
Yes, I have done they same thing at times. You can look up the resistor color coding or get a sheet on it. (black, brown, red, orange, yellow, green, blue, violet, gray, white). If I remember Black = 0, brown = 1, etc. Now a lot of electronics uses surface mount technology much harder to replace components without proper equipment. Always use solder made for electronics, usually has the flux inside it. Also, when replacing resistors make sure the wattage rating is the same or higher and on caps, the voltage rating and sometimes polarity.
1986 928S
32 valve engine
Old 04-21-2011, 04:57 AM
neil30076's Avatar
Leo, shot me a high res picture of both sides of the pc and i'll tell you how to check it out.
Neil
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-21-2011, 08:19 AM
MPDano's Avatar
Thanks for the offer Neil but the day I bought a good used one, I sent mine to a place that said they can repair it. Bad timing as I sent it in the morning and then was offered a good used one for a great price right after that, so I bought it.
Old 04-21-2011, 08:03 PM
