Alternate Kick Down Relay?
Is there an Alternate Solution or do we have to use the exact one? Just wondering as the Relay is $60
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
For auto trans?
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
Yup, Automatic Tranny
Used one ok? I let the fuse panel from my auto go to a local guy with. 5 speed. Bet you two could work it out. If you're interested in a working used one let me know and ill have him chime in.
Didn't hear anything from vdubr's buddy so ordered me the Kick Down Relay and a couple ones that use the same as the Horn Relay.
Hopefully this $60 Relay fixes my Kick Down In-Op. My Euro doesn't have a Kick Down Relay but must be hard wired. I had a few bad relays in my "S" CE panel so I bet this will work. Will keep you all posted.
Yikes! Just notified by Pelican that the Kick Down Relay # 92861810900 is NLA. Still looking for one then
I was wondering if the Switch under the Accelerator Pedal is a grounding switch. I'm not very good at reading schematics, so does anyone know the answer to this question?
The reason I ask is once I get my Kick Down working, I want to install a KD Bypass switch that is lighted. They are 3 prong so I assume I need one of the prongs to be ground.
Recovering dismantler
Leo, the kick down switch provides 12v from the '15' rail to the relay pin 30, so it is not a grounding switch.
Wire your light between K1 and ground, and it will be on when KD switch is active.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach Last edited by neil30076; 04-20-2011 at 11:46 AM.. |
Thanks Neil! Exactly what I needed. Looks like a non-lighted rocker switch is what I need.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Yup, theres a little circuit board in there. I opened it up to see if there was any obvious signs of it being bad. Nothing noticeable. I already bought a good used one from the 9 source about an hour ago. He said it's tested so if this doesn't solve it, then it's gonna be the part on the tranny.
You can do either, if you want the switch lite all the time, connect to the light + to the circuit 15 side, if you want it to light only when kd bypass switch is hit, connect the light + side to K1.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Does the k1 wire have a different color that you can tell?
Looks like the K1 wire is gr/br - the other wire on the kd switch under the gas pedal is black, which is the '15' wire, should should be easy to find!
I was able to fix an old CRT Monitor and an old HD 30 Flat Panel TV a few years back by looking at an obvious burned Cap/Transistor or a broken circuit, then by using a diagram (schematic?), figure out the proper Cap, Resistor that belonged there. Using my handy dandy soldering iron, flux, paste and a magnifying glass, I was in business. It's been a few years but I think it had to do with the bands and colors. Anyways, that's what i was looking for. If I had to resort to any testing, it made it's way to the dumpster.
Neil
Thanks for the offer Neil but the day I bought a good used one, I sent mine to a place that said they can repair it. Bad timing as I sent it in the morning and then was offered a good used one for a great price right after that, so I bought it.
