Porsche Crest Failed emissions: NO ppm-- HC , both excess
Failed my emission NO ppm 100 points
Hi all;
been through the posts on emissions, no qt. no answer
my NO ppm limit 1438; tested at 2135; mode 5015
my HC , limit 187 tested 282 ppm.- MODE 5015, others tests OK
I have new O2 sensor premium bosch, 16 months ago. The only thing is the cat.
I have a new air, oil fliters, distributions and all belts. Spark plugs, aren,t new, spark electriccal lines has 3 years old, valve rubberts has 12 months, but wanted to pass the test.
also tires are 35
WHat can I do to get the NO ppm and HC down?, Any tricks, tks guys..
thanks
Old 05-07-2011, 12:41 PM
MPDano's Avatar
Here was my Results before and after my Magnaflow Cat was changed.
Before:
15mph
HC=128
NO=136
25mph
HC=87
NO=133
After:
15mph
HC=11
NO=156
25mph
HC=44
NO=126
Change your Cat to bring that HC down.
This was on a CIS car, just so you know, but will yield same results. Here was my thread: http://porsche928forums.com/viewtopic.php?f=9&t=4&st=0&sk=t&sd=a&start=410
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-07-2011, 04:03 PM
Thumbs up
Thanks DP, but do you think replace the Cat is the only way? and ..what about NO oxygen gases, change a Cat give me a solutions too?
Old 05-07-2011, 05:04 PM
MPDano's Avatar
Well, as you can see that the NO isn't what was lowered. It was my HC. Here's my other 928, that I did some work on and it did lower the NO. Main things done were all Rubber (Couplers, Vac Lines, etc) replaced, New O2 Sensor and Injectors Serviced and Flowmatched at WH.
BEFORE:
AFTER:
Old 05-07-2011, 05:18 PM
MPDano's Avatar
Oh BTW, that Blue looks awesome
Old 05-07-2011, 05:21 PM
Thumbs up
Great diference before and after¡¡ very good work-
Ok. I follow your advices, as I see, give you greats results.
I, m happy you enjoy my new light blue color, today the weels are black .. like a photo..
Tks MP.
Old 05-07-2011, 06:26 PM
Petie3rd
Mrmerlin's Avatar
rrbd where are you located?
what year is your car?
For best running try using the least expensive Bosch super copper tips
about 1.99 at autozone
WR7DC or PN # 7900
Old 05-07-2011, 09:44 PM
Thumbs up
Hi Merlin; I,m located in Santiago, Chile. South America. (where was the Miners rescue remember?)
My 928 S year is 1985, USA version.
I,m looking for new spark plugs, as you recomended, Bosch WR7DC, super cooper, and clean the inyectors, as DP, said.
Any other necessary tips? I apreciatte that.
Old 05-08-2011, 09:33 AM
Petie3rd
Mrmerlin's Avatar
you may need to get the MAF rebuilt as well as replace the ICV and a new O2 sensor and possibly new cats
Old 05-08-2011, 12:14 PM
Porsche Crest
Tks, excuse me, what means MAF and ICV ?
The O2 sensor y replace it until 16 months ago, but I don,t use my car every day, just WE, and no more than 80 miles per mounth.
But last week, I participed in the first PORSCHE FESTIVAL in "Las Vizcachas" Speed Way, and went to 140 mph in 4 gear, at the end of the circuit, and brakes, (have a big rotors) suspenssion, (manual regulable coils), and have a kevlar estabilizador bar up engine) and engine function very well, but btn 3.600 and 5.600 RPM, in 2 nd. Gear the engine, feel no continue upper RPM increase ir regular form (like cof cof cof) and feel little explosion in the exaust system, in 3 d. gear does,t feel anything strange... and 4 normal too.
But was a mi first time in the circuit, amazing experiencie, everythig very safe, where 140 Porsches and only 3 928. And I finished 3ed, place in a regulation rece where you must doing the same time (1" minute, 3 sc. for 15 laps, and the organization put inside te copkit one "transponder" to look your time. Grate..
Old 05-08-2011, 01:15 PM
Petie3rd
Mrmerlin's Avatar
MAF = mass airflow unit just under the aircleaner
ICV= Idle control valve under the right hand rear of the intake manifold after you remove the aircleaner you can see it .
the combination of all these worn parts will make your car run lousy also consider replacing the ignition wires as they are prolly worn out as well,
get the good ones from Roger,
BERU they are plug and play
Old 05-08-2011, 01:39 PM
Porsche Crest
The replace of these parts, MAF and ICV seems easy,
BTW, Who is Roger ?
Beru is a trade mark international .
Old 05-08-2011, 02:42 PM
Petie3rd
Mrmerlin's Avatar
Roger@************ sell parts , fast shipping, best prices
Sells Beru wire sets, the good ones
Old 05-08-2011, 08:25 PM
Thumbs up
Maybe is a same dealer called 928 international, where y bougth some parts, but I make a very good quotation from them, your recomended dealer, pelicanparts and "perfomance", was I used, because all the items suggestion to get down emissions are near to U$5.000
Old 05-08-2011, 09:34 PM
Network Native
Danglerb's Avatar
Several sources including Roger offer rebuilt Maf, and while you may need a cat and ICV, I would start with clean injectors and a rebuilt MAF. Fixing all the vacuum leaks would also be good.
Old 05-09-2011, 02:16 AM
Ok, I,m going step by step, it sound better. tks. Danglerb
Old 05-09-2011, 07:05 AM
