power windows
i put in a new coil today, got in it and hit my pass. side window button on acc. and the window went down about half way and it wont go back up, does anyone know what that problem would be? its going to rain here all week and would like to get it back up ASAP1 anyone? help!
Have you ever changed the switch? it has a pig tail plug that connects up under the glove box. From experience with both 1978 and 1979 cars the switches have two problems: 1) over time the contacts develop a "green" copper corrosion on the surface that inhibits circuit contact, 2) the thin "leaf" contact fatigues over time and deflects away from making contact. If you are a surgeon with good dexterity you can disassemble the switch (taking great care not to drop the small ball bearing that centers the leaf) clean the contacts and bend the leaf back slightly to make contact. then reassemble with the ball in the proper position....good luck.
power windows
thanks so much!
If you can't get the switch to work again, disconnect the switch about twelve inches under the center console and jump 12 volts to it to drive the window up. Or just use the other switch. Can be a pain accessing the disconnects, but it's worth the effort just to have your window up.
power windows
thanks ill try that if the switch doesnt work
Also, you may have a broken wire in the door. Try slowly opening and closing the door while holding the switch in the up position. You may find the sweet spot and drive it, then you'll know you have bad wiring or a bad switch.
I actually made a jumper set of wires just for this purpose. Pull the connections loose, then jump known good switch to bad window. If this does not work you have a problem either with the wiring to that window motor or the motor itself. BUT...it seems these motors last forever....but I'm sure they don't. I've just never had a bad one.
I can see from the service record that my car had both window motors replaced at some point. The windows still didn't work. Didn't when I bought the car either. I replaced a $30 relay - whooptie freakin doo they worked like a charm after that!
Could just be a fuse, too - always check the fuses first ;) |
power windows
what relay would it be? it only has a fuse to it unless my sheets are not correct...doesnt say window motors under any,except #21 fuse,no idea..damn this car! lol
What year car are we talking about??? US or Other? I suggest you add the info in your signature so others will know what car your asking about.
power windows
its an 80'
US auto. i took out the switch and it seemed fine,turned it around too, and window still wont go back up! |
Next, take two leads, one for ground, one for 12 volts, apply them to the motor side of the disconnect under the center console. Switch the positions in the disconnect until you make the window go up. You can get power out of your CE. Lots of open slots with 12 volts just sitting there. Remember to slowly open and close your door while applying power. |
thanks ill try that and see if it works! thanks so much i tryed to add my info but the site wont let me.
power windows
i fixed it! the connections in the switch were dirty,so i cleaned contacts and it went right up! thank you all so much for the help!!!
power windows
i turned the switch around,down window up,up window down...didnt help till i cleaned the terms. now i got that passed me, the car wont start-no spark? MPDANO help me out! all grounds cleaned,new coil,fresh gas and nothing! no spark!
Voltage at Coil? Green Wire condition? Where was the last place you were working on the car? Maybe bumped something in the CE panel?
| All times are GMT -8. The time now is 11:00 AM. |
