1982 928S
georges 928S's Avatar
Question Diffrence in power 82 against 83 U.S.
HI Guys,
is there lot of diffrence in power between 82 versus 83. iam looking to make a
decision weather its worth buying the 83 just for that reason. Thanks Ed.
Old 05-09-2011, 07:22 PM
Maleficio's Avatar
Is that the 4.7 liter in the 83?
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-09-2011, 07:32 PM
1982 928S
Re: 83
Yes malficio, i think they used 4.7 ltr in all 83 U.S. models. ED>
Old 05-09-2011, 07:48 PM
If your talking US Models Its 12 HP More for the 83
Old 05-09-2011, 07:55 PM
Maleficio's Avatar
If I had to choose between 2/10's of a liter, I'd choose the car in the best condition.
Network Native
Danglerb's Avatar
4.5 vs 4.7, not real issue I think, but the rest of the S package, like S brakes ... maybe worth it.
Picking the one in the best condition not a bad idea either.
Old 05-09-2011, 09:40 PM
Dean_Fuller's Avatar
The main difference is the 82 will have a 3 speed auto and the 83 has the 4 speed auto if I am remembering correctly. That makes the biggest difference. If both are manuals then really no difference.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 05-09-2011, 10:39 PM
MPDano's Avatar
I have both. Like Dean says, the big diff is the 3-4 speed Auto. My 3 speed is a dog when the 4 speed isn't. I do think in my opinion that the 4.7 seems to have more power, but it's been so long since I drove my 4.5
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-10-2011, 05:02 AM
Pete R's Avatar
My friend had an 83 5 speed US. It was freakishly faster than other 928's. We could never figure out why but I ran very well. We thought it had a Euro motor but the injection and engine # were US.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-10-2011, 05:07 AM
928: Serial Enabler
We've got an 84 that seems freakishly fast, too.
Wondered if somebody stuck euro camshafts into it when replacing the front sheet metal with a Euro clip.
84,85,86 928 cars
Old 05-10-2011, 05:55 AM
European Shark
riber.bentsen's Avatar
The 86 euro comes freakishly fast from the factory
Seriously, one has to think twice about going WOT on public roads. Scary-fast...
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 05-10-2011, 06:57 AM
European Shark
Must be down to the gearbox/ratios, since the Euro 4.5 is rated 240hp, and the '83 4.7 stands at 238 (more torque though).
Old 05-10-2011, 06:59 AM
MPDano's Avatar
No, remember my Euro engine was seized. It has an 82 US 4.5 in it now. You mean you didn't read all of the 58 Pages of my Thread? The shame
Old 05-10-2011, 07:19 AM
Pete R's Avatar
I installed that Euro motor in my 79. That motor in the early (lighter) car works very well.. I agree. I still don't think it's as fast as my 944 Turbo though.
Neon SRT4 track car
Old 05-10-2011, 07:27 AM
European Shark
Sorry, brain fart.. I remembered it like you got a US block and put all the Euro CIS-crap on it. That would make euro-power, right?
Old 05-10-2011, 12:10 PM
European Shark
They must have put a million horsepower in mine Or maybe it's because it is lightly optioned. Cloth seat centers, vinyl panels (leather weighs a lot more), no sunroof, no rear AC, small stereo (no amp), and it has the seats without heating, memory or lumbar-support.
I don't think it weighs more than your 79 actually?
Old 05-10-2011, 12:14 PM
Pete R's Avatar
I'm not up on the weights. I know they gained about 500lbs through the run. I was about 3200 stock. Minus all ac components, cruise control stuff, no sunroof, no air pump, no mechanical fan, 32v tubular headers,no cat, lighter Borla exhaust, and Sparco seats WAY lighter than the leather elec ones). I added an electric fan and about 50lbs of stereo gear. So I should be under 3000... but who knows. It definately scoots with the 85-86 Euro.
Neon SRT4 track car
Old 05-10-2011, 03:31 PM
You can add on a Lot of power by reworking the distributor > simple if you know how .
Porsche 928 motor numbers and more
Old 05-10-2011, 04:26 PM
Maleficio's Avatar
Okay: any tips on reworking the dist? Links?
Old 05-10-2011, 06:58 PM
Any good speed shop can set it up > ( Distributor on Machine )
what you want to do is increase the initial timing way up > That means you must limit the total advance > Each Shop has It's own way to do it > ? Like copper Tubing over stops ? custom advance plates and the like
One good way is to set up a Extra Distributor in case you want to reinstall the stock unit say for smog perhaps
You can limit the stops of the advance plate .
Now if your initial timing is jacked up some 20 Degrees then you must take off about 20 Degrees on the top end. Other tuning may be in order like colder plugs
You well not want / need the Vacuum advance > you convert the Unit to a Mechanical Unit
If you don't want to be all that radical you may want to try perhaps a GT Distributor . I have not checked out the advance curve but no doubt they are different
Experiment with your initial Timing after setting the Unit up until you get the best results
If you get Spark Knock at top end then you have " not set it up right " . Play with the timing at this point perhaps backing it off say 3 to 5 degrees at a time until you get a a no Knock top end. Your elevation well be a factor .
Do not operate the car with Spark Knock get it right or you well damage something.
I expect their are several here that can steer you to some shop to set the Distributor up to your need's
Here is a Link for example
602-604 Racing DUI Distributor
another Link :
http://www.setyourtiming.com/Timing_Settings.html
Old 05-10-2011, 08:27 PM
