Can I get away with just replacing the boots on my rack/pinion?
I don't want to replace the entire assembly, just the boots. One is torn, the other side has fluid in it. The car won't pass the safety inspection because of it.
Is it a monster job to replace the boots?
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
I need to know this one too.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
928: Serial Enabler
Can be done with rack installed. Need to pop the tierod ends off the hub. No alignment needed.
Clean the tierod ends real well to remove dirt / sand. You don't want sand carried into the boots Cut the old boots away. Rinse/clean shafts. Slip the new ones on. Use some silicon grease to help. Dwayne documented this in one of his treatises.
84,85,86 928 cars |
Thanks, Chris.
928: Serial Enabler
I use a fork tool and a small sledge. I lube it first with silicon grease to hopefully not tear the rod end boots.
Stan can probably tell us the right tool to use, some sort of press.
84,85,86 928 cars |
There is a much greater chance of damaging the boot with a fork tool. Use a tool like this:Universal Tie Rod End Remover | Mechanics Tools Warehouse
The hardest part is sliding the inner part of the boot on the tie rod.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
The boots will get you through inspection but won't solve the fluid issue. You have a bad seal. If you plan on addressing it you will want a rebuilt rack, I'd do the boots then. It may even come with new boots.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Thread Tools | |
Rate This Thread | |
