what type of ATF fluid to use
All:
Need to top off the ATF fluid in my 1987 928 getting a bunch of differing recommendations. So which is the correct ATF fluid to use. Understand the wrong fluid will ruin the seals Thanks as always Provenceman |
Engineer of profanity
The reservior cap says Dexron 2. I use Castrol mult vehicle. It satisfies the need for Dexron. Next time I'm going to use whatever Mercedes uses for Dexron.
DON'T put import car trans fluid in it.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
Castrol Dexron 111 HUMMMM
Here's the link Which ATF to use now? - Rennlist Discussion Forums Mobil 1 ATF >>> Mobil 1 Synthetic ATF that sounds good to me for a good condition Auto Trans But if it has a bunch of miles humm not necessary Just a Dexron type is fine and just change it once a year > only about 8 QT's |
ATF fluid
Thanks very much for the quick response
Much appreciated Provenceman |
Petie3rd
I have been using Dexrton 3/4 Its made by Valvoline its called Max life,
The same fluid is also used in the power steering
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
