how do you add coolant?
Hey, I am trying to add some coolant to my 928s. I can not get any room to remove a cap or put it in. Any advice?
Old 03-10-2002, 09:49 AM
928 coolant tank caps are difficult to undo, but use a pair of grips and you should be able to release it. Obviously make sure the engine is cold when you do this. Check the cap and renew it if the rubber washer is perished. Use only the proper BEHR cap, US caps have the wrong pressure.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-10-2002, 11:25 AM
Sorry Wayne, I should have been clearer. Porsche run the cooling system at a higher pressure than most US cars; therefore if you fit a pressure cap from the local auto-parts store it will allow coolant to leak out due to the opening pressure being too low.
Old 03-11-2002, 08:33 AM
Yes, the pressure that the cap operates at is higher for Porsche models than most domestic cars.
Usual auto-parts cap pressure; 7 - 10 psi
Porsche 15-20 psi
Old 03-11-2002, 12:55 PM
Hey! Nice Rack! "Celette"
rich's Avatar
How interesting.. I never noticed that.. great info.
Old 03-19-2002, 09:54 PM
Senior Member
Hello
Most Mercedes use a similar cap.
Grüsse
Old 03-26-2002, 05:36 PM
