how do you add coolant?
Hey, I am trying to add some coolant to my 928s. I can not get any room to remove a cap or put it in. Any advice?
928 coolant tank caps are difficult to undo, but use a pair of grips and you should be able to release it. Obviously make sure the engine is cold when you do this. Check the cap and renew it if the rubber washer is perished. Use only the proper BEHR cap, US caps have the wrong pressure.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Author of "101 Projects"
"US caps have the wrong pressure"
I don't quite understand this statement? ??? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Sorry Wayne, I should have been clearer. Porsche run the cooling system at a higher pressure than most US cars; therefore if you fit a pressure cap from the local auto-parts store it will allow coolant to leak out due to the opening pressure being too low.
Coolant pressure? Do you mean that the cap (which is sometimes designed be pressure relief?) would break at a different pressure?
-Wayne
Yes, the pressure that the cap operates at is higher for Porsche models than most domestic cars.
Usual auto-parts cap pressure; 7 - 10 psi Porsche 15-20 psi
Hey! Nice Rack! "Celette"
How interesting.. I never noticed that.. great info.
Senior Member
Hello
Most Mercedes use a similar cap. Grüsse |
