Ignition switch question
I own a 1982 928. I have a new ignition switch that i'm trying to put in. Do I have to pull out the center console to replace it if so how? Also what kind of screws are holding it on? Allen, phillips, or some special tool?
Old 01-12-2012, 05:59 PM
nuts4porsche's Avatar
ignition
there is a thread on here about how to take out the pod,and re-install,may have come to me from MPDANO.i have a pic of the paper but its a little hard to read.
80 US auto
Old 01-12-2012, 06:24 PM
Dean_Fuller's Avatar
Those directions look good....no need to remove any of the center console.
NOTE...when putting the switch in. Make sure the switch is in the OFF position. They must test them from the manufacturer and will sometimes leave it in the ON position. I installed one in the ON position and as soon as the battery was connected everything came alive and the key could not be moved in either direction.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 01-12-2012, 06:46 PM
Engineer of profanity
924CarreraGTP's Avatar
I've done it countless times without removing the steering wheel. It's a little more surgical but nothing for the previous owner of a Fiat X1/9
My way is to just undo the cover from under the binnacle, take the allens out, leave the electronics plugged in and very gently manuever the right side of the binnacle intact with the instrument cluster up and over the igntion switch arm of the steering column. It might take some slight yanking, but I've never broken anything. One time the cluster came unplugged, but it just plugs back in. It's a 20 minute process if you're careful and have some hair on your peaches. The switch comes off the back of the column (under the binnacle) with two screws. Easy as pie. Oh yeah, important thing. Getting the binnacle out from between the blinkers can be a little tricky. Wiggle them around the binnacle by switching them or holding them in whatever manueverable position they will go without breaking. Like it said, it's not that hard. I've never broken anything.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 01-12-2012, 07:10 PM
928: Serial Enabler
This is one job where you really need to disconnect the battery first or you will have a big mess.
84,85,86 928 cars
Old 01-13-2012, 01:43 AM
I agree about disconnecting the battery. I'm saying leave the electronics to the binnacle plugged in. You should always disconnect the battery when working on anything.
Old 01-13-2012, 04:10 PM
PCA Certified D.I.
Just wondering why you are replacing the ignition switch. Are you fixing some kind of starting problem?
Old 01-14-2012, 06:18 PM
