82 928 euro atm/lsd
Shes running!!!! Finally
i cleaned out the wur and checked for clogged lines and found the line from the fuel dist to the wur was loose at the fuel dist so i diconnected the line and cleaned it out. i ordered a new fuel filter and dist cap and rotor from pelican parts and installed everything and shes purring nice.
1979 928 5 speed 90k
Old 08-18-2012, 06:04 PM
Congrats--another shark on the prowl
Way to go--mine was sitting for 3 years and after some $$$ and love its up and running also. Now the trick is to figure out all the electrical bugs. Have all grounds done except the tight fit by AC drier--tomorrow's challenge. Keep all 4 on the ground if you can.
Old 08-18-2012, 06:15 PM
MPDano's Avatar
Awesome! Now drive it. CIS needs to get cleared out and driven.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-19-2012, 06:17 AM
Kool
AirtekHVAC's Avatar
Great to hear! Congrats!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 08-19-2012, 06:44 AM
82 928 euro atm/lsd
drove it around the block a couple of times and had a blast.(ITS DEFINITELY SHARK WEEK) i have a rad leak from the neck of where the the pass rad hose connects.its a small crack, is that repairable because its plastic or just replace it with a all aluminum rad.??
i also tried to put on a belt that i purchased from 928rus that bypasses the pollution pump but i couldnt get it to go on it was to small. does anyone know what mm size belt i need
Old 08-19-2012, 08:41 PM
MPDano's Avatar
FYI, I went with a good used Behr with warranty from 928 Intl. You'll need to know if you have a single or dual cooler. Also, that belt will need to be the next size up. It's hard to tell which one you'll need so I bought both at NAPA, then returned the one that did not fit.
Old 08-19-2012, 08:44 PM
82 928 euro atm/lsd
i just looked at the price for a new one holy smokes. i think i should just buy a parts car. theres a 81 for 700 bucks not to far from me. i guess everyone by passes that pump with that belt. mine is making noise but other than that just getting it to run right is half the battle. i can repair everything else. i have a nice shopping list rr axle boots, rack boot leaking on rt side. i have already done slave cyl, plugs, cap, rotor, tbelt ,tensioner, brakes, cleaned contacts and replaced all fuses.
i did notice that the cars charging gauge is reading 12volts but when i put a charging meter on the battery its reading 13 volts on my meter. ever see that in these cars?
Old 08-19-2012, 09:07 PM
stepson's Avatar
Roger at 928sRus sells the end tanks and new end tank seal for @ $100. Then you just have to get it replaced. Pelican may sell them also but IDK for sure.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-20-2012, 09:22 AM
MPDano's Avatar
That's the hard part, getting someone to do it or do it yourself. It's been explored here in San Diego and no one will do it.
Old 08-20-2012, 10:42 AM
SanDiego928's Avatar
I found one in San Diego.....Art's Radiator Repair in Spring Valley. Great guy, they do plastic end repairs all day long. Showed me how they do them. Would have cost about 75 to 100 for labor as I remember.
Since mine was looking pretty shabby and has been repaired a few times, it looked like, I went with a used Behr from 928 intl. Great used radiator. No problems and has a 1 year guarantee.
Mark
1981 928
Old 08-20-2012, 11:34 AM
MPDano's Avatar
Oh, I stand corrected as I thought you never found one.
Old 08-20-2012, 12:58 PM
