928: Serial Enabler
Mine too.
Xlot, thanks for the encouragement via data points on your install. Pete also! Am getting some pressure to get this car out of the garage; it seems that I have the collars wound-down further than they were before beginning this, so maybe the 3 greens will give similar results. They have same force rating as 3 browns, but just 10 mm greater in overall starting length. Fingers crossed. It gets pretty cold up here in Indiana, and snow flies soon. Wife has traded my 85 no spoiler platinum car for my son's (was mine) Wrangler, at least for the winter. She refuses to be stuck in the house. So the 85 just moved into the maintenance que with urgency. |
928: Serial Enabler
Later today we torque the bolts, remount the sway bar, and maybe get the hubs and brakes installed.
First, a shot that contrasts the S4 spindles with the S spindles they replaced. Note the difference in lower ball joint orientation. Also note that the caliper bolts mounts are in a different plane. ![]() ![]() |
Kool
Cool
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
928: Serial Enabler
Torqued.Shields on.
Hubs are next. Note that the brake rotor backing shield is larger so must be changed to the S4 version as shown. They are painted steel on 86.5/S4 instead of aluminum on early S. The aluminum S air deflecter that feeds the brake rotor cooling fins is also different. The S version doesn't have the curl at the top. Either appear to be usable in the conversion though. 86.5 version is shown installed. See the federalization attempt? Carbon canister in upper right. Will need to remove that for fender liners to fit. Might not be a bad idea to transplant the 86.5 stock canister. Just in case. ![]() ![]() Last edited by Landseer; 11-23-2012 at 04:52 PM.. |
Petie3rd
Chris its looking great here....
quick while no one is looking remove the metal collars for the washer tank and the fill tube, rinse out the tank while your at it
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
928: Serial Enabler
Bearings well-packed, hubs on, stabilizer bar remounted. Ready now for brakes and rotors.
Thanks, yes, now is the time to fix the windshield washers. Iron sleeves are gone already, but more work to tank level detector needed. Question. What is process for setting front suspension? Lower control arm mounts are barely snugged. Top control arm bushing nuts are also barely snugged. Do I put on tires, lower the car, then torque them all? Not sure I can reach the top ones. ![]() ![]() |
For the lower control arm - torque both front bolts. For the rear bolts at the alloy C clamp, the WSM states to leave the bolts loose - 2 threads exposed from memory (but check). If they're loose as specified, the suspension will settle almost immediately and you can check ride height quickly without driving the car 50 miles between adjustments (I usually drive 100m or so including a couple of bumps into/off our driveway, just to make sure).
Various manual S4's |
928: Serial Enabler
Calipers and rotors fitted.
Old ones are in pretty good shape Will get new pads and rotors before driving season begins again. Used Xlot's method for setting suspension and torquing the remaining bolts. Next step is hydraulics. Removed and cleaned up all 8 bleeders. Started filling with ATE blue. Ready to bleed. ABS may take a little more time. ![]() ![]() Last edited by Landseer; 11-24-2012 at 06:01 PM.. |
Is the car on the ground yet? Or still tidying up brakes etc.?
928: Serial Enabler
I torqued it under load, then set it back on jackstands for the bleed.
Pictures were taken before torque was applied to the front lower control arms' rear bolts. Fortunately I used the grey antisieze, not copper. Can re loosten them, then lower it, and re torque. But will save that for last. I'll read the front suspension section of the manual again, too. Thanks for helping me! Remaining mechanical jobs: Bleed. Hookup emergency brake cable. Torque the rear adapter spacer nuts. Put four wheels on the car and lower it. Break the mega-tight outer axle nuts free. Raise car, remove wheels Remove / flush clean (I hate that part)/ repack / refit 86.5 rear axles. (One of outer boots looks like it split, maybe recently, but I have to assume grit entered. I loosened all the inner flange bolts while the rear suspension unit was sitting in the driveway.) Retorque the rear suspension. Change the manual transmission lube. Then refit the exhaust. Lower car and torque lower control arms, rearmost mounts for settling. Then have the car aligned. This is a lengthy project. NOTE --- the stainless steel aftermarket S brake lines on my car with rounded ends are the wrong ones for S4 brake calipers, which take a rectangular fitting that prevents rotation. The S ones do "fit". But due to orientation they can VERY POSSIBLY work loose at the caliper. I need to buy new lines safe and suitable for the S4 calipers that "lock" into place on the calipers. The donor car has them, but they are too old to use. Last edited by Landseer; 11-25-2012 at 12:13 AM.. |
OB Wan
Did ya get it on the road today?
Jim Doerr - 928 Classics http://928classics.com '77 ('78), Preproduction Press Car, 9288100016, 'Number Six' '78 US, 5 speed, #225 '78 Euro/RoW, 5 speed, #1075 '79 US, 5 speed, #0954 |
928: Serial Enabler
Am close.
Changed the plan, as we discussed. Bled brakes. Just removed 86.5 axles. Have a set of good 85 axles to slip on tomorrow night, temporarily. Then exhaust. Then drive to align. I've got to get this car out of the garage bay. Meanwhile, will repack the 86.5 axles for when I get into the antilock. |
928: Serial Enabler
Am very close now. I don't think front is going to settle. Looks like a Willy's gasser.
Going to check with Dr. Tyson on price / availability of Eibach front springs. Else white /green S4 units. |
OB Wan
Dumb question: Is it possible the front shocks are on the back and visa versa?
GAFB
What did you do about wiring up the ABS and pad wear sensors? That's an open issue on mine.
You *might* be able to fit a front shock on the rear with a lot of brute force, but no way you could get a rear shock on the front.
The reason they take a while to settle normally is that large rubber bushing which is held captive against the crossmember by the alloy C-bracket rotates and binds. When the rear bolts of the LCA are loose, it can rotate fairly easily to the settled position - although I usually roll the car and dab the brakes to make sure its down.
OB Wan
928: Serial Enabler
Drove a little bit last night.
Well, major success overall. Its been a long time since "Chewy" could accomodate a 3-2 or 2-1 downshift. Suspension is going to settle pretty high. Driving around neighborhood with bolts loose. Will show pictures. A set of used Eibach springs is on the way which can be swapped-in if necessary. Quote:
Am inclinded to swap-in the full ABS car harness. But I think the sensors could be spliced into the original harness instead. The brain has been swapped but is not plugged up. I've got to map the wires, pin outs and especially fuse box connections yet. Will document that. I want to fix it. |
Kool
Good work Chris....great write up.
Thread Tools | |
Rate This Thread | |
