Heater control problem
Hi Guys,
It starting to get cold and I have noticed that the heater doesnt work... I checked the heater valve and it looks fine. It closes when I start the car but it doesnt open when I turn on the A/C or just move the slider to "Eco" like it did before. I have disconnected the vacuum line to the heater valve but although hot water are now flowing in, there is no heat coming out of the vents ![]() It seems that this problem divides into 2 parts: 1. Heater valve not opened (valve checked to be fine) 2. Internal heater flap probably closed so the hot air is not coming out of the vents. Is this a familiar problem? What can I do in order to check / fix this issue? Thanks for your help!
Porsche 928S 4.7L 1980 European redhead
Petie3rd
go to Wallys tips at
928 SPECIALISTS ONLINE STORE - 30,000+ 928 Parts - 928 SUPERCHARGER KITS! look on page 2 under tips and links, find the HVAC system and do some reading lots of things to check, and once you figure out whats bad its easy to fix
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Thanks!
