1980 Porsche 928
My list of problems with my 1980
So I recently took my 1980 on her first trip. I was blown away by how nicely the car drives. The acceleration is unbelievable and it is a lot of fun to drive. I owe you all here on the Forum many thanks because you guys have helped me on so many things, and I just want to thank you all again for your help. There were some things I noticed that werent working so I will just list them for you, hoping this is my last list of problems
1. Car seems to start better when the engine is cold and I have to crank it about 3 or 4 times when the engine is warmed up.
2.The horn does not work and I would really like to know where it is located!
3. The fresh air fan does not turn on so I can not move heat throughout the car or defrost. I thought it might be the relay as I can not here anything click when I turn the fan dial. Is there any way to test the fan or test the continuity. How do I get to it also.
4. The speedometer stops working at about 25 mph, I cleaned up the 4 wire plug in the rear by the battery but it did not help. What else could it be and how do I fix it or check? It feels like it shifts whenever the speedometer shuts off
5. Cruise control does not work. I could not get the cruise control to turn on, im not sure if there is a relay for it or not. I did replace the cluster switch at the dash recently though. I know there is a computer but would it go bad after just sitting around? Would the cruise control have something to do with the speedometer shutting off??
6. Car has a rough idle when youre at a red light. Seems to surge a little bit. Idles at about 500-600 when its in gear. 850-900 in park.
7. When I turn on the main headlight switch it turns on the headlights the running lights and the right inner front light, fog light I believe, than when I push the middle light button for the fog lights it turns on the left fog light. Kinda seems like something is wired wrong to me. Also when I hit the horn the left fog light turns on
Thanks for any and all help.
Caleb
Old 11-10-2013, 11:24 AM
stepson's Avatar
#2 Horns are located in the passenger fender area in front of the wheel.
#3 Fuse #17 is the fresh air blower. Check for power there.
#5 Cruise control is fuse #10. Likely culprit is a vacuum leak, though. Vacuum is probably a cause of your rough idle also.
#7 You've got some FUBAR wiring which is causing this and probably your horn not to work. The connections for all these are at the very front of the car. Probably just connected to wrong harnesses???
Good Luck
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-10-2013, 02:52 PM
1980 Porsche 928
For the electric blower fan the fuse was burnt out, put a new one in, starts glowing red and smoking, didn't really blow it. But the fan would not come on. Tried to different relays. Idk if either work though.
The horn fuse is fine.
Old 11-12-2013, 02:46 PM
Porsche 928 Fanatic!
Position X on relay chart - 2 tone horn relay
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 11-12-2013, 03:14 PM
1980 Porsche 928
I know that's the relay. You can hear it click when you hit the horn. I'm assuming it's the horn itself. Main concern is the blower fan and vacuum leak.
Old 11-12-2013, 03:30 PM
SharkHead
JhwShark's Avatar
With the issues and number 7 particularly...you may want to investigate behind the big fuse/relay board for cross/shorting but may choose to pull the pod and clean contacts first, something is going on and with your #7 description the pod may be the starting point if you see no visible issues with wiring at the board.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 11-12-2013, 03:36 PM
1980 Porsche 928
That has already been done but thanks for the advice!
Old 11-12-2013, 03:43 PM
Kool
AirtekHVAC's Avatar
First time I powered my refurbished CE it smoked out....caused by the locked up blower motor. I pulled it out, lubed the crap out of it with kroil every night for 2 weeks, and kept working it back and forward until it spun free. Works pretty good connected to a battery. I then bought a newer, nicer one on eBay for $30... Now I have a spare!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 11-12-2013, 04:17 PM
1980 Porsche 928
This thing seems to start smoking before you even turn the switch to turn it on. How do I access the motor easiest??
Old 11-12-2013, 05:47 PM
Kool
AirtekHVAC's Avatar
Remove hood, remove cowl....passenger side....there are a few threads here and RL about removing. Mine smoked as soon as I turned the key.
Ron
Old 11-12-2013, 07:08 PM
1980 Porsche 928
Please tell me there's a way to do it without taking off the hood! Haha I'll look for them! Thanks for your help!
Old 11-12-2013, 07:24 PM
MPDano's Avatar
The hood is aluminum. Just mark the bolts on the hinge so it will line back up on re-installation.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-13-2013, 05:07 AM
1980 Porsche 928
Does anyone have a link to the removal thread? I'm having a hard time finding one
Old 11-13-2013, 01:00 PM
MPDano's Avatar
It's like two bolts on both sides. No need for a thread on how to remove bolts. It's light so it's easy to handle.
Old 11-13-2013, 01:44 PM
1980 Porsche 928
On the blower motor not the hood!
Old 11-13-2013, 02:31 PM
stepson's Avatar
After the premlinary stuff (Hood, wipers, and cowling)is removed, remove the rubber seal between the motor and the evaporator. Just inside are 2 short screws. Remove them. Go to the passenger footwell. If you have a package tray, remove it. After the package tray is removed, look up at the footwell fresh air flap mechanism. There is a long hex headed bolt near the center of the flap and towards the rear of the car. Remove that long long screw. Your blower motor is now ready to remove.
I will tell you in all honesty that I just replaced a blower motor in a friend's car that had bad bearings with a new high powered (more CFM) motor that I got from 928sRus, and the difference is remarkable. The new motor/fan can literally part your hair from the side vents. The price is comparable to a new replacement motor.
If I ever have a blower issue on my own car, I'm getting one these new blower motors.
Old 11-13-2013, 03:53 PM
1980 Porsche 928
How much do the new ones cost? I'm trying to get one without spending too much money.
Old 11-13-2013, 04:51 PM
Network Native
Danglerb's Avatar
That bottom screw on my car was covered in tar/sealant and I couldn't see it, had to feel around then clean the area off. Messy job, not all that hard, not really one I would car to repeat.
Problem I see is that the life of a used blower isn't predictable, and while some have drilled the bearing cover and put in oil and tried to reseal, doesn't seem like much of a long term fix.
Old 11-13-2013, 07:08 PM
1980 Porsche 928
Got the motor out fairly easily. But I'm unaware of the best place to buy a new one. There appears to be good talk of one roger sells but I do not wish to pay $600
Old 11-13-2013, 07:14 PM
Kool
AirtekHVAC's Avatar
I got mine on eBay....lucked out as it is from a newer car, but I think Rogers is a smashing deal, and I heard it was priced reasonably.
Old 11-14-2013, 11:20 AM
