Mike the mechanic's Avatar
Installing 928 engine, need help
Hey guys, I am installing a 1980 928 engine, which I did not remove, and I am having trouble connecting some vacuum lines. Does anyone have a vacuum diagram??
If not, can anyone tell me where the thin metal vacuum tube connects to? The one that is bolted to the front of the intake manifold, runs alongside the body and ends up near the firewall. What does this connect to??
Also, where does the vacuum advance for the ditributor connect to?
Thank you in advance!!
Mike
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 09-17-2002, 05:48 AM
Senior Member
Hello
Carbon canister vent line ?
Vacuum advance is at the throttle body ( ROW not sure about US )
Grüsse
Old 09-19-2002, 12:46 AM
Hi Grusse, thanks for the reply, the vacuum line I was referring to was actually the automatic transmission modulator vacuum signal.
I have a few more questions though... I can't seem to locate the starter solenoid wire. You know, the thin wire that activates the starter when you turn the key... I can't seem to find where it should be coming from!!
Also, there is a wire harness coming from the alternaor and starter harness that runs along the front of the engine, near the timing covers. It runs to the right side of the car to the side of the fender. It consists of 3 wires, one thick one that obviously connects to the power distribution center on the right inner fender, but it also has two other little wires with loop connectors, but I can'y seem to find where these two should connectn to. Anyone???
Thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 10-05-2002, 06:48 AM
AFJuvat's Avatar
"Grusse" is a closing statement - kind of like "sincerely" translated it means "greetings"
Mit freundlichen grüßen
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-13-2002, 12:30 AM
Thanks, Mit fruendlichen gruben.
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 10-13-2002, 12:42 AM
AFJuvat's Avatar
hehehehehehe
that funny looking "B" is a double "S"
I'm not intending to be a prick, just having a little bit of fun.
PM for some information about your problem.
AFJuvat
Old 10-13-2002, 12:54 AM
I know you weren't trying to be a prick! I was just having fun to cover up my embarrassment
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 10-13-2002, 01:14 AM
