LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
I have a 1980 928, I was wondering if you have the specification for the amount of r-12 needed to refill this a/c system
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I do not. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick |
hi Charles
I thought you could not use R-12 any more?? it should only be R134. the availability of the r-12 gas in UK at least is near non existant
Porsche 928 S4 1989,Auto, 93K on clock, gun metal grey with cream interior. Coulsdon, Surrey, UK Last edited by Big Load; 05-08-2014 at 02:42 AM.. Reason: spelling error |
Network Native
EU is way farther out, they are dropping 134, with R12 long history, but in the USA you can still locate R12 around $25 / lb in 12oz cans (old stock).
You might have to do the filling yourself after a shop makes sure your system is not leaking, as many shops no longer have the equipment to fill or recover r12. Below from a post by Griffiths. R12 1978-1979 R12, 950 grams or 33.5 ounces 1980 - June 1988 Revised Factory recommendation, Single evaporator systems R12, 1050 grams or 37 ounces Dual evaporator systems R12, 1200 grams or 42.3 ounces July 1988 - 1992 Single evaporator systems R12, 950 grams or 37 ounces Dual evaporator systems R12, 1150 grams or 40.5 ounces *before you attempt to charge using refrigerant weights stated above, always check in the engine compartment for the factory R12 sticker, and verify the charge using an R12 Pressures and Temperatures Chart R134a 1978-1982 R134a, estimated 807 grams or 28.5 ounces 1983-1992 as per TB, 9501, 12/19/1995 Single evaporator systems R134a, 860 grams or 30 ounces Dual evaporator systems R134a, 1030 grams or 36 ounces 1993 onward Original Factory recommendation Single evaporator systems R134a, 860 grams or 30 ounces Dual evaporator systems R134a, 1050 grams or 37 ounces *before you attempt to charge using refrigerant weights stated above, always check in the engine compartment for the factory R12 sticker, or an R134a retrofit sticker, and verify the charge using an R134a Pressures and Temperatures Chart |
