928 Bro's Avatar
Spark
Hey guyz so this is a pic of how my new spark plug looks after just going around the block. Let me give you the run down. Car sat for 10 years, I did the fuel pump, fuel line, wire harness. Turned on the car 7 to 10 sec of cranking. Sounded good but slight miss fire. I didn't change plug(they were brand new Bosch platinum's). So I put new plugs and did the timing belt- found that the #1 firing setting was off on the distributor. So I was getting burnt porcelain plugs on one side and raw fuel (they came out all wet. Now I'm getting burnt porcelain plugs but dry. Any ideas can help. Thanks
Old 05-20-2014, 02:31 PM
stepson's Avatar
You are wasting your money buying platinum plugs. There are all kinds of stories about problems with 928 engines that have been cured by buying el cheapo copper Bosch plugs. I actually have a couple of my own, but copper is the way to go, not platinum, not iridium, just copper.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 05-20-2014, 04:54 PM
928 Bro's Avatar
Hate answering my own questions, But can this be a result of my injectors pissing fuel instead of spraying a mist pattern?
Old 05-20-2014, 04:55 PM
Yellowb1rd's Avatar
hmmm. If your injectors were pissing, you risk fuel lock, which has its own set of nasty issues. You could drain the oil, and see if there is petrol in it, if you suspect an injector(s) is dumping fuel, or you could check the oil level to see if it's higher than it should be. I'm assuming you mean a big stream a fuel as opposed to a fine mist...
Old 05-20-2014, 05:03 PM
928 Bro's Avatar
I didn't buy the Bosch platinums, they were in the car and looked brand new that's way I didn't change them right away. Got regular plugs now. Yellowblrd I'll check oil tomorrow but before I did the timing and new plugs, I was worried about that because all my plugs were wet with fuel when I pulled them out. Now they are dry but burnt on one side and car is running better but still rough. After 25 mph to much vibration
Old 05-20-2014, 06:02 PM
Petie3rd
Mrmerlin's Avatar
correct Bosch plug part number is 7900 found at Autozone. Wr7dc silver tips
Remove the injectors and send them to Whitchunter,
dont run the engine till this is done
Old 05-20-2014, 06:11 PM
Network Native
Danglerb's Avatar
Sending the injectors out to a good service, there are a few some a bit cheaper than Witchhunter, removes a whole segment of potential problems. I'm thinking it should be one of the default actions of a new owner.
Old 05-22-2014, 08:10 AM
928 Bro's Avatar
Ok so I got my injectors back. I am very happy with the vender I used. I got a report of how they were working before service and report after. They are 100 % now but on average they were working at a 86% capacity. For under $150.00 including shipping, they serviced them, got the reported, changed strainers, changed the plastic nozzle, put new fuel lines, clamps and the 2 rubber rings and painted them. They look brand new. I'll install tomorrow hopefully my problem is fixed.
1980 928 Auto
Old 06-14-2014, 05:13 PM
Petie3rd
Mrmerlin's Avatar
use some Dow Corning 111 on the O rings this will keep them pliable and make installation into the manifold and rail easier
Old 06-14-2014, 06:16 PM
928 Bro's Avatar
Vibration problem gone. There is a slight miss fire but it let's you drive before the vibration was so violent that you felt that pieces were going to fall off the car. Plug wires are next on the list. Thanks
1980 928 Auto
Old 06-15-2014, 01:18 PM
Network Native
Danglerb's Avatar
What injector service did you use?
Old 06-15-2014, 11:05 PM
928 Bro's Avatar
Mr.injector
1980 928 Auto
Old 06-16-2014, 05:26 AM
MPDano's Avatar
Very nice. You'll get the same service at Witch Hunter, except that short piece of hose and clamp.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-16-2014, 12:23 PM
Network Native
Danglerb's Avatar
For reference the full info.
Mr Injector - Home
Mr Injector / Bill Johnson
6280 N Government Way #4
Dalton Gardens, Idaho 83815
208-762-3450
Any gas injector cleaned for $16 plus actual shipping, ala $5 for priority mail.
Old 06-17-2014, 12:35 PM
Kyle C
Cool! Glad to hear the cleaning worked.
I used a place called Metro Fuel Injection in Massachusetts a few years ago, not terribly impressed. I think the data sheet they gave me was made up. Pulled all my injectors recently and rigged up a tester at home, 7 of 8 are seeping under pressure, worse than the set of used ones I purchased!
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 06-17-2014, 06:01 PM
928 Bro's Avatar
Thanks Danglerd for giving full info. Google makes me think lazy. I assume anymore that I just have to give a word and people will google right away
1980 928 Auto
Old 06-17-2014, 07:11 PM
