Tony928's Avatar
what's this part called
hi there. there is a part that doesnt quite read correct on the ohm meter. i was wondering if anyone knows what this part is called and how it might affect the engine.
1982 US automatic
-it's the brown part-
-the picture is the front of the engine -
Old 06-01-2014, 03:52 AM
19psi's Avatar
I believe that is your "temperature time switch" for your cold start injector.
George in Indiana
928 Weissach #153
Cayenne S
Old 06-01-2014, 06:01 AM
928 Bro's Avatar
Double check the Manuel but I believe that depending on the temp the ohms reading can change just make sure your within range
1980 928 Auto
Old 06-01-2014, 06:50 AM
Network Native
Danglerb's Avatar
I think some may be measured pin to pin, others pin to ground.
Old 06-01-2014, 09:19 AM
Madman
Not sure, but i think that one combines a thermocouple with a switch so you'll get some whacky readings depending on the temp and how you are measuring it.
1979 Porsche 928 3sp auto, black (gone)
Yamaha FZ6R, Raven Black. (gone)
1997 VW Jetta GLX VR6 swap in. black (gone)
1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's)
Old 06-01-2014, 10:04 AM
