what's this part called
hi there. there is a part that doesnt quite read correct on the ohm meter. i was wondering if anyone knows what this part is called and how it might affect the engine.
1982 US automatic -it's the brown part- -the picture is the front of the engine -
I believe that is your "temperature time switch" for your cold start injector.
George in Indiana 928 Weissach #153 Cayenne S |
Double check the Manuel but I believe that depending on the temp the ohms reading can change just make sure your within range
1980 928 Auto |
Network Native
I think some may be measured pin to pin, others pin to ground.
Madman
Not sure, but i think that one combines a thermocouple with a switch so you'll get some whacky readings depending on the temp and how you are measuring it.
1979 Porsche 928 3sp auto, black (gone) ![]() ![]() ![]() Yamaha FZ6R, Raven Black. (gone) ![]() 1997 VW Jetta GLX VR6 swap in. black (gone) ![]() ![]() 1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's) |
