Yellowb1rd's Avatar
This is what happens when a tiny piece of metal gets stuck into one of your cylinders
...not for the feint of heart, gents. It ain't pretty. This is what happens when a tiny washer finds its way into your #3 cylinder after removing/replacing the fuel injectors. A very expensive error resulting in a replacement engine, and a valuable lesson learned not to be repeated. Worthy of tears, for sure.
After removing the heads to inspect the damage...
Old 05-20-2014, 05:44 PM
928 Bro's Avatar
That sucks. Hate to see that, feel for you.
Old 05-20-2014, 05:52 PM
Dean_Fuller's Avatar
Ouch.....looks like coffee table material now.
Hope the new motor works out for you.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 05-20-2014, 06:31 PM
Antsmands
antsmands's Avatar
That Sucks! Sorry for your loss!
1983S 5 Speed / Platinum Metallic / Dark Brown Interior / GE NightHawk LED Headlights / Super Bright LED / Flex-a-lite Cooling Fan / Dragon Gauges / Custom Auto Sounds Spare Tire Sub Woofer / H3R HalGuard Fire Bottle
Old 05-21-2014, 08:42 AM
928: Serial Enabler
What is your location?
84,85,86 928 cars
Old 05-21-2014, 04:20 PM
Network Native
Danglerb's Avatar
Nasty results, not that uncommon of a mistake. Head doesn't look "that" bad, so maybe just a shortblock and you are good to go.
Old 05-22-2014, 06:09 AM
Strosek Ultra's Avatar
A number of years ago I bought an engine having exactly the same failure. Some red neck mechanic had dropped a nut into one of the cylinders when the car was at service. The block is now machined out for sleeving to 108mm bore. It will be a 7L stroker in time.
Åke
Old 05-23-2014, 06:12 AM
Fixer's Avatar
Yellowbird,
Was this the first motor or the replacement motor you just purchased not
too long ago?
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 05-24-2014, 07:17 PM
80 928
Ouch!
Old 05-29-2014, 09:37 AM
Yellowb1rd's Avatar
Originally Posted by The Fixer View Post
Yellowbird,
too long ago?
Apologies for not responding earlier fellas... BZ week!
This was the motor that I ruined (the original). It was easier to lift the motor out of the garage with the heads off, and I wanted to see the damage anyway. The replacement is already in the car, almost everything is hooked up, and nearly ready to start. If the replacement motor had that damage, I would feel the necessity to drive it off of a cliff, with the remaining seven working cylinders. LOL! This project has been a PITA, with too much time and $$$ spent.
Even harder to stomach. I inspected all the remaining cylinders and they were absolutely brilliant, with no scouring or wear whatsoever. It was a very strong and well cared for motor before the damage (caused by removing and replacing the injectors). Now it will become a table - a VERY expensive table at that, but hey, good art isn't cheap....
Old 05-31-2014, 04:56 PM
