Dan951's Avatar
Question About 1985 928S Front Engine Harness
I can't seem to find the oil pressure sender wires in the factory wiring diagram. I must be blind?
Can anyone tell me the color codes and wire gauge of the oil pressure sender wires for a 85' 928S? I'm trying to rebuild my front engine harness that connects near the jump post using the 14 pin connector.
Old 04-19-2016, 04:57 PM
Recovering dismantler
neil30076's Avatar
Page 3 zone K-25
14 pin Terminal 2 Oil pressure terminal WK blue/black stripe
14 pin Terminal 4 Oil pressure terminal G Blue/white stripe
14 pin Terminal 6 Oil level switch Green/blue stripe
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 04-20-2016, 05:49 AM
Dan951's Avatar
Thanks Neil! Probably would help if I was looking in the right spot. I was under the engine portion of the wiring diagram.
Does anyone have a good wiring diagram color decoder?
Old 04-20-2016, 06:06 AM
Dan951's Avatar
Never mind I see the color code now. Thanks again for the help!
Old 04-20-2016, 06:19 AM
