drola's Avatar
O2 Sensor Fitment question MY80
I bought a new oxygen sensor. But when i went to replace it i found that there is not enough clearance between the bung and torque tube for the sensor to fit. Which explains why the old one had the wire sheared off at the top.
I believe the one i bought is a universal single wire sensor. Is the 928 specific sensor shorter in length? I really don't see how it could possibly fit.
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 11-27-2016, 11:50 PM
Network Native
Danglerb's Avatar
Needs picts, is the exhaust original? Motor mounts and hangers?
All the O2 sensors seem about the same size to me.
Old 11-28-2016, 11:59 PM
Mal81's Avatar
My cat has two "bung holes" heh heh.
My sensor is installed in the angled one and the one on top is plugged. I believe that several aftermarket units are configured this way also.
1981 928 Euro "Babied and Pampered"
Old 11-29-2016, 07:33 AM
drola's Avatar
Car has stock exhaust as far as i can tell. It has the bung pointing straight up. I'll take a look to see if it has an angled one which would make the most sense because there is absolutely no way a standard o2 sensor would fit in the vertical bung
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 11-29-2016, 07:48 AM
stepson's Avatar
Is the car a Euro model?
M28/11 or M28/12 engine code? ZZZ in the vin#?
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 11-29-2016, 10:08 AM
drola's Avatar
car is a 1980 US version
i looked at the cross piece in the y-pipe and it only has the vertical bung for the o2 sensor
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 11-29-2016, 11:46 AM
One solution, if you don't have a second bung that would allow for an easy install, have a muffler shop weld in a new bung. Should not cost too much, and they would have the car on the lift, and could install your new O2 sensor. Good luck with your project.
Old 11-30-2016, 06:09 AM
Kyle C
Is the Y-pipe original? Does it have a catalytic converter in it? I used to have a "test-pipe" in place of my catalytic converter on my 1984 US model, and the O2 sensor bung placement in that pipe was incorrect, causing the O2 sensor to hit the torque tube as you mentioned. On the stock catalytic converter though, there was plenty of clearance. Definitely post some pictures of the Y-pipe.
Here is the Y-pipe with poor clearance:
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 12-01-2016, 06:55 AM
