944 addict
a/c compressor install problems
I bought a new Denso compressor for the a/c and verified the part number. After servicing the unit prior to install I started having issues with getting it to fit. I micrometered the mounts and found the mounting ears were 1 mm too wide so I carefully dressed them to snugly fit. Still after two days of effort, I still can't get the bolts to go in. There appeared to be some interference spots at the top so I filed them down and I still can't get the bolts to go in. Am I the only one who has encountered this or is it a common issue with compressor replacement?
I've gone over the parts diagrams and pictures and watched videos so I'm still at a loss for where the problem might be.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Last edited by mytrplseven; 10-29-2019 at 02:30 PM.. |
In the Fires of Hell.....
Not had this issue with many compressors.
Have you tapped out the sliding bushing to allow for the compressor to fit?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
944 addict
I have not. The bolts go through easily but alignment seems to be the constant issue. The lateral position seems to be haunting me. I've given up for a few days to collect my thoughts and see if anyone else has dealt with this problem.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
i dont remember, but does the late 944 bracket have the "metal sleeves" that slide back/forth?
you knock them back to "wide" spacing, slide in the compressor, and threading in the bolt draws it tight. like an alternator bushing. |
Super Moderator
yes there is a tensioner bolt on the bottom that controls the lateral spacing.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Not that, I'm referring to bushings in the accessory bracket, that mate up to the hanging ears on top of the compressor.
Super Moderator
can you post a photo of what you're seeing?
Super Moderator
are you sure you're not trying to install it upside-down? notice there are 'ears' on both top and bottom in this diagram:
https://www.pelicanparts.com/More_Info/94412600800M11.htm?pn=944-126-008-00-M11&bt=Y&fs=0&SVSVSI=
944 addict
Yes, I'm sure it's not upside down. The measurements between the ears are different than the proper mount. I plan to remove the hose to the condenser and try again. It's just to damn hot in the garage right now. I'd post a picture but it's too cramped, dark and trying to hold it up while trying to take a pic just won't work.
are you sure you have the right compressor for your car, or the right AC bracket?
the early vs late(82-85 vs 85.5+) are slightly different spacing. |
944 addict
I am, I checked the part number before I ordered it.
944 addict
compressor install SOLVED
I was finally to get the compressor in after I removed the hose to the condenser and hammering the rear mount sleeve to were it didn't interfere with the mounting ears on the compressor.
