Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
The newest of the noobs!
grendiers's Avatar
Power steering issue
My ‘89 car never had a modern feel to its steering. Which I assume is normal. Or not! The rack was replaced years ago, and doesn’t have a ton of miles on it, maybe 20,000. Anyway, it’s developed squeaks on hard turns left and right at slow speeds, say backing out of the garage. I replaced the original reservoir today and no improvement. No leaks from the pump. Back in the day you could crank back and forth to eliminate air in the system. I tried that and didn’t help. Any ideas? Currently, 81,000 miles on the car.
Old 09-09-2023, 01:00 PM
soxnail's Avatar
1- Does it only happen at end of full travel with pressure on the wheel against the hydraulics ?
I.E if you are still in full turn but the steering is barely backed off from full hard turn does it go away? If so on both sides or only one side.
2- Can you pick the front of the car up and try turning the wheels fully both ways but with no tire rotation and it still happens ?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 09-11-2023, 02:23 PM
grendiers's Avatar
Tires on the ground only. And happens not at full extension, but close. Mostly the worst on driver side.
Old 09-12-2023, 06:46 AM
In the Fires of Hell.....
kdjones2000's Avatar
Squeaks like your PS belt is too loose?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-13-2023, 05:45 AM
grendiers's Avatar
No, a hydraulic one! The steering wheel shudders, not smooth on the tight turns. I’ll pop the 47 bolts on the middle panel and check belt tension, look for leaks or problems with the rack. After the A/C compressor install, the knuckle busting fuel filter replacement, solving the idle surge problem, I’m a bit worn out from on this. I’m old! Ha!
Old 09-15-2023, 07:09 AM
soxnail's Avatar
While you are in there push the boots down on the pistons and look for lines, scratches damage on them.
Sox
Old 09-16-2023, 07:18 AM
Super Moderator
nize's Avatar
how old is the power steering reservoir? i recall there's some sort of filter inside it on the bottom that eventually gets clogged. the solution is to just replace the entire reservoir. it might be time to replace it with a new one which is an easy job and a $40 porsche part.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-16-2023, 08:49 AM
