951 Max Chip installation? Where is the KLR and DME computers
I am going to Pop in my new chips soon, However i was wondering if anyone had a diagram of where the location of the KLR and DME computers are located. and What chip on the board needs to be replaced. Sorry this is a noob question
thanks Jason |
Dme/klr are located in the passenger side, under the foot board. There is a write up on Clark's site about it.
both chips are in the same place in dme and klr (only dme pic posted). Sox ![]()
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Sox you are like the default answer every single question arent you?
thanks alot man. Do you have the link to the write up? thanks again
1986 Bmw 325 5spd (turbo) 2002 Nissan Spec V 6spd (for Sale PM me!) 2001 Honda Civic 1986 Porsche 951 5spd Guards Red (Stage 1, w/ 89 Turbo S Lsd Trans!) |
Hey just payin back for all the help people on this board have and continue to give me.
![]() link http://www.clarks-garage.com/shop-manual/dme-02.htm Sox
Super Moderator
where did you purchase these chips? if you got them from a reputable source, they should have arrived with clear instructions on how to install them correctly.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Super Moderator
which turbo? which chips? list your full mods!
there's also a chance you may have gotten counterfeit chips if you got them on ebay, as that's a popular scam.
its the Speed Force racing Stage 1 its a turbonetics turbo
My car doesnt really have too many mods right now its in the process of getting everything installed Currently sits pretty stock here are the mods that will be in it by the end of the week Spec Stage 3 racing clutch SPI Boost, Water temp, oil temp gauge Lindsey racing a-pillar pod Lindsey racing boost enhancer (mBC) Bosch 3.0 FPR 46lb injectors Max 951 chips AEM intakecone OBX BOV SFR turbonetics stage 1 turbo short shifter running 18psi nothing major thanks
Super Moderator
ah okay. any reason why you went with the sfr turbo if you're only going to be running 18psi?
be careful using the LBE, there are lots of write-ups and debates about it. biggest drawback is that it will disable the stock overboost protection. if you already have a max951 chip, why are you going with the sfr chip? or is it the other way around? and the clark's garage site has a great writeup on chip swap. here is another great chip install write-up; http://members.rennlist.com/951_racerx/ChipsInstall.html
18 for daily 25 for track. Dont want to blow my motor.
I have the max 951 chip Not the sfr chip. i think sfr may use max 951 chips too. What exactly is the LBE write up of? its almost common sense to install.
Super Moderator
you really don't like searching, do you?
![]() Lindsey Racing Boost Enhancer What's purpose of the "venturi tube"?
Dog-faced pony soldier
You don't even know where the computers are in your car and yet you're "okay" with modding it out with parts of dubious origin?
This is gonna' end badly. Dibs on the carcass. Do you happen to have LSD transmission? I need one of those.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Anyways STock boost control? You forget or may not know i own a 86.. the year that had the wastegate problem. When i bought the car i thought it was fast... why? because it was over boosting to 2.0 bar. Wastegate gets stuck.... but thanks for the info |
Super Moderator
yeah i was gonna say.
how do you know the parts are genuine, etc. maybe i'm just paranoid but there are a lot of scams and scammers out there.
Super Moderator
btw, what wastegate problem? how are you sure the wastegate is getting stuck? how have you validated this?
and yes its a common problem apparently search google for it (the wastegate gets stuck and doesnt open or opens and doesnt close.) Also currently i just realized the car doesnt actually hit boost. I felt like i was over boosting before but now i realize the boost gauge (stock) measures absolute pressure? if thats correct? and at atmospheric pressure it should be at 1bar.? I never hit over 1 bar just recently occured.. could be the wastegate.. |
Super Moderator
i'm aware of the wg getting stuck open/closed, i don't believe that's a 'common' issue. it usually points to a car that has been parked outdoors and/or not driven regularly, as the wg will corrode.
what i was wondering, is how were you able to validate your wg is actually the problem? and yes, the stock gauge measures vacuum, so 1bar = atmospheric pressure. stock boost is around 1.8bar, or ~11psi over atm. although it is a possibility, just because you're not getting boost, doesn't mean your wg is stuck open. lots of things can cause this. also, what about the sfr turbochargers and such? have you validated their authenticity ?
as for the SFR turbocharger. They do use turbonetics turbos and the trim size is the same. and the turbo is Infact turbonetics. So i have no doubt its is one of their turbos |
Super Moderator
how do you know it's not a knockoff? sfr isn't the only company that sells turbonetics. someone could have also cobbled one together and claim it's an sfr turbo when it's actually a cheap copy, etc.
i'm not sure how to positively identify an sfr turbo, though.
well Nize the fact is. If or not if they got a turbo and chip together. Its the same components that turbonetics uses. I Dont know any company that makes "fake" turbonetics turbo chargers. And also happen to be direct bolt on for 944 turbo. The trim size and A/F are the same as the SFR specs. Even if it didnt originate from them. It originaated from the same place SFR got it from. And the SFR turbo is just turbonetics. SFR is a retailer they use other manufacturers parts. Just like if you get a turbonetics T66 from MVPmotorsports or you get a turbonetics T66 from Lindsey Racing Same thing. just sold by different people. For safe measure i may get the chip retuned.
But i understand what you mean. You are pretty parinoid by everything haha. I guess being 100% sure is good
