Front end vibration and humming noise
From 50 mph on up my 951 has a vibration in the steering wheel and hums while turning left or right. The issues seem to come from the passenger side. I originally thought it was a cupped tire but that doesn't seem to be the case. I put it on stands on everything seemed tight. I rotated the two front tires and the vibration/humming is still coming from the passenger side. Not sure if it's a wheel bearing or not. The vibration and humming seems to come and go. It definitely hums more on smooth roads. Any ideas?
winter-hater club member
could be the wheel bearing. may be the rotor.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
It is the wheel bearing. if it happens more when you turn a certain direction then it is that one. turn left = rt wheel bearing. turn right = left wheel bearing.
87 951 = home made MBC, Large Turbo, Autothority MAF, Mafterburner, custom fuel system w. 55lb injectors, 951MAX chips, water/mentanol injection, 2-stage Nitrous injection, punched out cat, Magnaflow muffler. 944's are like kids, the average owner has 2.5. |
Super Moderator
figure out what caused this yet?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
No, not yet. I am waiting for my new wheel bearings to arrive. In the meantime I had the front tires balanced which helped a little. It's still a issue and am hoping it's the bearings. Would that cause a vibration though?
Super Moderator
yes.
