Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
c_rice_99's Avatar
Front end vibration and humming noise
From 50 mph on up my 951 has a vibration in the steering wheel and hums while turning left or right. The issues seem to come from the passenger side. I originally thought it was a cupped tire but that doesn't seem to be the case. I put it on stands on everything seemed tight. I rotated the two front tires and the vibration/humming is still coming from the passenger side. Not sure if it's a wheel bearing or not. The vibration and humming seems to come and go. It definitely hums more on smooth roads. Any ideas?
Old 09-05-2007, 12:03 PM
winter-hater club member
nynor's Avatar
could be the wheel bearing. may be the rotor.
"COOL PRIUS!" - Nobody Ever
Old 09-05-2007, 04:20 PM
It is the wheel bearing. if it happens more when you turn a certain direction then it is that one. turn left = rt wheel bearing. turn right = left wheel bearing.
87 951 = home made MBC, Large Turbo, Autothority MAF, Mafterburner, custom fuel system w. 55lb injectors, 951MAX chips, water/mentanol injection, 2-stage Nitrous injection, punched out cat, Magnaflow muffler.
944's are like kids, the average owner has 2.5.
Old 09-07-2007, 02:05 PM
Super Moderator
nize's Avatar
figure out what caused this yet?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-11-2007, 01:27 PM
c_rice_99's Avatar
No, not yet. I am waiting for my new wheel bearings to arrive. In the meantime I had the front tires balanced which helped a little. It's still a issue and am hoping it's the bearings. Would that cause a vibration though?
Old 09-12-2007, 07:01 PM
Super Moderator
nize's Avatar
yes.
Old 09-13-2007, 09:14 AM
