Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Architecture & Porsche's
Rear hatch RATTLE, not squeek, I have both...
squeek is the seal: needs more leather oil to quiet. But I have a rattle as well, sounds like it's coming from the top of the hatch: very annoying: common? remove panels & find out or is it someting that always rattles??
mark
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-10-2008, 01:59 PM
Super Moderator
nize's Avatar
you sure it's the hatch and not sunroof?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-10-2008, 02:19 PM
the rattle is there whether the roof is raised or flat, & pressing on it while driving does little to stop it, but it might not be that simple of a rattle too.
Mark
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-11-2008, 06:08 AM
In over my head
If it is the rear hatch sound like delamination of the glass from the frame. There are degrees of fix - from complete R&R to stop gaps like flowable silicone. Does it leak during the rain?
Fergus
86 951 Graphite Metallic
86 944 n/a Garnett Red Metallic (SOLD!)
74.5 Triumph TR6 (restoration project)
05 Subaru Legacy (winter car)
Old 07-11-2008, 11:34 AM
No leak, just rattle. Don't see any delamination upon inspection, though it appears my tint is starting to peel at the top edges...great.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-11-2008, 11:37 AM
Turbo_Euro951's Avatar
I have been here, There are two latches that hold your hatch in place. Because the Car is kind of old these catches have worn out.
In my case the stud that actually sticks down into the catch rusted and broke. These parts are relatively cheap(The studs I mean). However it could just be an adjustment. The catches themselves can be adjusted or shimmed to tighten up the fit. The studs can also be moved in or out....unless they are rusted like mine. But if the rattle is happening when you go over a bump or railroad tracks and your positive that its not coming from the roof( which also goes out of adjustment.....plastic gears are CRAP!) then the adjustment on those catches would be the first place to look.
Old 07-14-2008, 01:58 PM
My hatch latch studs appear solid & working, I can see the cutter-M8 bolt coming up through the hinges when the hatch is open, & there's no shimmy-ing when the hatch is open.
I need to ride in the back of my car over bumps, see if I can pin point it.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-14-2008, 02:05 PM
Have you tried lifting up and down on the spoiler to see if there is any play because if there is even a little it will amplify off the back glass and will be loud in the front seat. When you push the hatch button does it pop up like its supposed to or do you have to wiggle it.....that will be a tell tale sign as well. It took me a number of weeks of adjusting....riding....adjusting....cont... to get it right there were a number of times I would adjust it a little to much and it wouldnt make a noise until I went over a big bump and the hatch would fly up while I was driving down the road......One of the manytimes my car has made me look bad....but it makes me look so good too.
1987 951 Alpine White ....Kinda sick though
2008 Suzuki M50 Boulevard(The Bumble Bee)
1984 944 N/A...Sold (Taught Me Alot)
PORSCHE..There Is No Substitute..Until it Breaks.. HAHA
Old 07-14-2008, 02:38 PM
