Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Catch Can install - should I drill the AOS a bit ?
I'm installing a cheap ebay kit for $20, should I drill the AOS out a little when I install the catch can?
I do NOT want to pull the AOS and drill, but I will if it is required.
TIA
Old 12-12-2008, 09:45 PM
That Guy
Techno Duck's Avatar
If your venting the catch can to atmosphere its probably not a bad idea. Not necessary on a recirc type.
I would consider going with a recirc type so you keep a proper vacuum on the crank case.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-13-2008, 07:08 AM
Thanks Techno. I am reciculating the line back into the J boot.
Old 12-14-2008, 10:34 AM
