Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Manual boost controller problem.
I have a manual boost controller, and afte I fixed a very large boost leak, I had to re-adjust it. And I turned it all the way up, and it still kept wanting to boost to the moon. So as I was going to take it out, to run the line back to stock, I found the line to the wastegate had been melted shut. So I replaced it, and the line I replaced it with is much smaller in diameter, but now it's not boosting past 5psi even all the way down. Not sure if it matters, but the screw fell put while driving once, and I found it in the engine bay, and put it back in the controller. Could something have gotten messed up?
Old 11-02-2010, 05:43 PM
All Spooled Up
Maybe the ball or spring also fell out of it, rendering it non-operational.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-03-2010, 05:07 AM
I hear the ball. Could there also be a spring?
Old 11-03-2010, 05:17 AM
All Spooled Up
Yes, turning the adjustment in or out changes the tension on the spring, which pushes against the ball.
Old 11-03-2010, 05:32 AM
On Boost
Paulyy's Avatar
This happend to my friend when we put a boost tap on his skyline. one of his mates though he could put more power though it, accedently unscrewed the whole tap and lost the spring and left the ball inside. therefore the boost wouldn't regulate, so i found a spring that would work with it, put it in and adjusted the boost.
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 11-03-2010, 05:54 AM
All Spooled Up
Unless it's an LR product or something, for which a new one could be ordered, that's likely what tayloray will need to do.
Old 11-03-2010, 06:10 AM
Then I need to find a spring. Anything specific with it?
All Spooled Up
Make sure the OD of the spring fits inside, but isn't too sloppy. And use one that the wire is of a gauge close enough to the original, that will provide a similar adjustment range.
Old 11-05-2010, 08:09 AM
Super Moderator
nize's Avatar
i think it would be easier (and more accurate) to just buy another mbc.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 11-08-2010, 10:28 AM
