Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
Is there really 2 knock sensors?
I just noticed that PP lists these ( 944-606-145-00-M14) as 2 being required per car. I only ever noticed one on my 89 turbo - under the intake, near the ISV. Where is the other one located?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-21-2010, 06:07 AM
Rogue Tuning
Rogue_Ant's Avatar
There is only one knock sensor on the 951, regardless of year.
-Joshua
www.RogueTuning.com
Old 11-21-2010, 06:49 PM
I believe the second knock sensor was used on 3L cars (but don't quote me).
Darwin
1988 Porsche 944 Turbo S
944 Enhancement 3.1L
SFR//TecGT//Vitesse//LEDA
Old 11-21-2010, 10:29 PM
All Spooled Up
Pelican Parts - Product Information: 944-606-145-00-M14
They seem pretty adamant about the turbo having 2 of them That's why I asked. But it now appears obvious that it IS a mistake.
Old 11-22-2010, 03:55 AM
Super Moderator
nize's Avatar
there is a spot next to the single factory knock sensor to accommodate a second knock sensor, but it's taken up by the factory ISV bracket (i think, will have to double check). i'm actually planning to relocate the ISV bracket, and install a second knock sensor just as a failsafe.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 11-22-2010, 09:44 AM
All Spooled Up
That doesn't sound like a bad idea. Is there a connector for the 2nd one?
Old 11-22-2010, 06:28 PM
Rogue Tuning
Rogue_Ant's Avatar
Yes.
Not on the factory harness.
-Joshua
www.RogueTuning.com
Old 11-22-2010, 10:06 PM
All Spooled Up
If commencing such a mod, would you just wire it in parallel with the other one? Wouldn't that throw the sensitivity off? Or does it it need a separate line to the DME? If so, will the DME be able to read it without modification of the firmware?
Old 11-23-2010, 05:07 AM
Rogue Tuning
Rogue_Ant's Avatar
The DME does not monitor knock, rather the KLR does.
Adding a second knock sensor is not an option for the DME/KLR... nize is running a stand-alone engine management setup, so what he does is not a point of reference for anyone running the DME/KLR.
-Joshua
www.RogueTuning.com
Old 11-23-2010, 02:03 PM
All Spooled Up
How does the S2/968 handle the 2nd one then?
Old 11-23-2010, 03:59 PM
Rogue Tuning
Rogue_Ant's Avatar
Completely different DME.
-Joshua
www.RogueTuning.com
Old 11-23-2010, 04:03 PM
All Spooled Up
I c.
Old 11-23-2010, 05:22 PM
Rogue Tuning
Rogue_Ant's Avatar
Furthermore, on an inline-4 cylinder I don't see much of a point to adding a second knock sensor... There are only two ignition events per revolution, with good separation, so one knock sensor, placed reasonably, should be quite sufficient at picking up knock.
Adding a second knock sensor, especially so close to the first is only good for a redundancy-type of setup - in which one knock sensor fails (highly uncommon).
-Joshua
www.RogueTuning.com
Old 11-27-2010, 01:52 AM
Super Moderator
nize's Avatar
i'm installing the second one for redundancy, in case the first sensor fails.
Old 11-29-2010, 11:15 AM
All Spooled Up
Since I am using stock engine management hardware , I have no choice but to stick with a single one. That's fine though.
Old 11-30-2010, 04:31 AM
