Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Turbo alignment problems
Well my turbo got destroyed by a bolt, so I bought a used one, and before install I took the housings off and cleaned it. I forgot to mark the clocking. So I'm trying to test-fit it but no matter how I turn the cold side housing with it put together loosely, I can't seem to get the oil return on the bottom, and the crossover flange to both be aligned.
Old 03-13-2011, 08:48 PM
here are some pics. this is what i used to put mine back together
1988 944 turbo
Old 03-13-2011, 08:53 PM
note the dimple on top. also check out the other "stamps" and markings for reference.
good luck,
rick
1988 944 turbo
Old 03-13-2011, 08:55 PM
Thanks! I just based it off those, well see if I got it right
Old 03-13-2011, 09:06 PM
I cannot see the frame for the extra serial no plate on the back of the cold back plate. This indicates that it is covered by the outlet flange. This has to be mounted differently, away from the turbo mount. The frame protrudes enough to prevent you from mounting the turbo to the car. There should be a x stamped on the inside of the backing plate marking the trouble spot.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 03-14-2011, 01:20 PM
1988 944 turbo
Old 03-14-2011, 03:31 PM
sorry, i cant find any more pics
1988 944 turbo
Old 03-14-2011, 03:33 PM
Bolted up perfect, thanks again.
Old 03-15-2011, 12:46 AM
