Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Installing engine heat shield after turbo is in?
Almost done with my Vitesse Stage 3 install.
So I have all the brackets sorted out but now I'm thinking I'm screwed because I mounted the turbo before putting the engine heat shield that holds the rear intake manifold support in place.
Is there any way to get this heat shield in between the turbo and the block once the turbo in bolted in and connected? I am dreading the thought of taking everything out just because of this damn shield. It looks like the shield itselg may slip in there, but the intake bracket connected to it may not work (and no way to connect that bracket once the shield is down there).
I'm thinking maybe if that bracket were welded to the shield so there are no bolt heads and nuts sticking out and the raised edged are ground down?
Anybody been successful getting this shield in after the turbo was installed?
1972 911S Fully stock resto - SOLD looking for 911SC
1980 VW Scirocco 2.0L autocross
2020 Shelby GT350R
1981 MotoGuzzi Monza
1963 Ducati Diana MK3
Old 03-13-2012, 07:39 PM
In the Fires of Hell.....
kdjones2000's Avatar
I think you are SOL, sorry to say.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-13-2012, 07:43 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
I did the same thing, pull the turbo
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 03-14-2012, 11:43 AM
Super Moderator
nize's Avatar
a friend did the same thing, you'll have to pull the turbo.
i'll bet you'll never forget the correct order again.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-15-2012, 11:10 AM
Turbo is out and heat shield is in. And yes, I WILL NOT MAKE THIS MISTAKE AGAIN!!!
2020 Shelby GT350R
Old 03-18-2012, 08:11 PM
All Spooled Up
I took the lazy man's route, and cut a piece of it off, in order to make it go.
Old 04-14-2012, 11:54 AM
I too took the lazy route and sectioned the shield into two pieces. I sectioned almost vertically and bolted in the front half. And had a bracket welded to the intake support to support the rear section. It worked well with the exception of where the bolts were positioned. I tapped the thick part of the shield not knowing exactly where would be since shield was out. Turned out they were hard to access without a second set of hands since down pipe was in way. This allowed the whole shield to be in place.
Still not easy but easier for someone less mechanical. Hope helps someone in future.
Old 05-20-2012, 05:49 AM
