Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Boost Problem I need help!!!!
I have a 86 944 turbo. I have a manual MBC that i can turn al the up or down and will not change the boost level. I have a duel port wastegate, Lindsey chips, and the MBC. I cannot figure this out or havent looked in the right area. Please give me an idea where to look and what for. All parts are less then a year old. Thank you!!!
Old 09-13-2013, 04:49 AM
Well. Step 1. Check all boost related lines.
1988 944 turbo
Old 09-13-2013, 10:29 AM
BTERRY1's Avatar
Have you changed anything recently? Did you just install the MBC and problem started or is this a new issue on a car previously running fine. It is more than likely vacuum related. check all lines and report back.
Old 09-13-2013, 01:33 PM
All new lines and hoes. I have it hooked up all year just never got around to figuring it out. All lines check out fine. No leaks.
Old 09-13-2013, 01:58 PM
In the Fires of Hell.....
kdjones2000's Avatar
Well then either your vacuum wiring is incorrect, your waste gate diaphragm bit the dust, or maybe your MBC died?
Have you looked at Lindsey Racing's site for advice? I assume that they diagrams on how to hook things up.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-13-2013, 04:00 PM
Looked over it. All vacuums are correct. I have no idea how any of the two would be bad. How do i tell if they are bad. My car does boost to 10 but when i turn the MBC all the way down it goes to about 7, all the way up is 10 no higher then that.
Old 09-16-2013, 02:49 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Gordon15734;
Lower port on wastegate goes to manifold vaccum. Upper Port on wastegate goes to MBC out. and inlet pipe vaccume goes to feed MBC as your reference signal.
Use a mightyvac hand pump to check your wastegate operation.
MBC they go bad after a while (don't trust none of them...) Use a Greddy Profec B or Type s electronic BC for best control. Had mine for over 10 Yrs...You can tune in the boost response.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 09-16-2013, 09:26 PM
Tags
boost
