Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
911tracker85's Avatar
elec turbo WP alternative
during the process of refreshing this 951, had to replace the elec turbo WP.
new ones are a bit pricey and did not want to throw in another used one that may eventually fail.
searched ebay and found one for about $70, but did not have correct elec connector.
as the old WP was bad, just cut off that connector and wired it up. looks like someone had done this in the past also.
works great.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 07-13-2014, 07:25 AM
A water heater pump for older Mercedes vehicles works. The pump was used to circulate more water for the heater when the engine was idling if ambient temperature was low. There was one on my 1980 450SL, it costs much less than the Porsche pump, and it can be substituted. Don't know if they are still available.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-18-2014, 07:54 AM
I just searched ebay for it. found this one that works, but not a Porsche/oem. had to adapt the elec connector as shown in pics.
I had heard the Merc turbo wp would work, but did not have correct elec connector. not sure what the one I got was supposed to be for.
here is a link to it on ebay.
86 87 88 89 Porsche 944 Turbo Auxiliary Water Pump 95160613001 New FP05 | eBay
Bob Cox
Old 07-18-2014, 09:55 AM
Super Moderator
nize's Avatar
nice writeup! more info on the turbo water pump here;
Turbo pump fixits
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-19-2014, 09:00 AM
The most common MB pump used as replacement is # MBZ037173. It can be found at various online sources for $55-60. As mentioned, the electrical-connector is different. Not that difficult to cut off the wire from the old one and solder it to the new one.
There's an online-guide somewhere showing how to move the bottom pump-section from the old 951 pump to a different MB pump that has different hose-diameters as well.
One time, I actually bought a surplus 12v DC-motor for $10. The shalf was slightly too large and long, so milled it down to proper size and fitted the pump-section from the original 951 pump.
Old 07-26-2014, 08:49 PM
